LR three piece cross member
Old 04-18-2006, 02:03 PM
Porsche-O-Phile
Porsche-O-Phile's Avatar
The ones holding the three sections together.
Show me anyone that claims they can change a turbo in an hour even with a 2-piece x-over / 3-piece x-member and I'll show you someone in serious need of medication or a watch, 'cause they obviously have a seriously distorted view of reality or time - or both.
Old 04-18-2006, 02:19 PM
David Floyd
David Floyd's Avatar
Chris said he could remove a turbo in an hour not change one out. I think I could come close to the hour removal time, none of my bolts are old and rusted
Old 04-18-2006, 02:20 PM
Porsche-O-Phile
OK remove. . . maybe. If anyone was claiming they could do a replacement in an hour they'd have a spot on someone's F1 racing team by now. . .
Old 04-18-2006, 02:44 PM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Yep, just remove in an hour…..however if you install them with Velcro instead of bolts they do come out quicker than an hour!
The hour removal only works on cars that have been taken apart regularly…so the turbo mounting allen heads are not seized….
BTW – if really pressed for time I can get my head off in an hour also….!
Chris White
Oh - I checked in to see if there were any openings as a turbo removal expert fro F1 teams…seems they have no need for a quick turbo removal specialist!
Old 04-18-2006, 03:15 PM
DFASTEST951
DFASTEST951's Avatar
TonyG, thanks, Stage 2 it is. I wonder how much power to expect?
dand86951, I thought it was a power steering or alternator belt too. Changed them both already and it turns out to be the timing belt. Only have 15,000 miles. A bit early I think but don't want to chance anything.
Old 04-19-2006, 05:00 PM
DFASTEST951
Does this piece scrape the ground on a lowered car?
Old 04-19-2006, 05:01 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
it shouldn't. the crossmember is made from a factory piece cut into 3. it's no lower than stock.
Old 04-19-2006, 05:11 PM
kasturbo
kasturbo's Avatar
I bet I could do a replacement in under an hour. I would be cheating because I have the Lindsey intake and an oil cooled turbo helps. All I have to remove is the maf, two turbo bolts, 4 crossover bolts and the three down pipes bolts. Maybe a MC heat sheild if time permits.
Old 04-19-2006, 08:48 PM
sm
sm's Avatar
Originally Posted by Chris White
Its a must have. Get the cross over pipe mod too. With that comobo I can drop an oil pan in 30 minutes or remove a turbo is under an hour.
Chris White
With the 3-piece x-over, do you still have to support the engine from the top when dropping the oil pan?
Old 04-19-2006, 09:59 PM
David Floyd
Nope
Old 04-19-2006, 11:30 PM
Chris White
Rennlist Small
Business Sponsor
The center of the cross member drops out leaving the two ends with the engine mounts still attached to the body and engine. You also don’t have to touch the suspension – so no alignment changes.
Chris White
Old 04-19-2006, 11:58 PM
Mighty Shilling
Wax On, Wax Off
I am sooooooo getting these things... *drool*
Old 04-20-2006, 12:30 AM
KuHL 951
Hey Man
KuHL 951's Avatar
Has anyone ever made up their own 3-piece? I have 2 spare 951 crossmembers and know some very good welders.
Old 04-20-2006, 12:44 AM
ibkevin
Defending the Border
Rest In Peace
ibkevin's Avatar
PHP Code:
Let me know, I'd love to return the assistance you provided me during my install , seriously!
Old 04-20-2006, 03:01 AM
Mighty Shilling
Wax On, Wax Off
LOL! Kevin, that won't help!
Quick Reply: LR three piece cross member
