Vitesse - New items
#32
John,
My head was fully rebuilt by the dealer less than 6,000 miles ago. I'm interested in your sledgehammer head and a cam to go with my Stage 3 turbo. What do you recommend, how much will it cost and what gains should one expect? I also anticipate going with a set of Speedforce headers down the road.
#33
SoloRacer, when you install the larger valves, it's advisable (almost necessary) to replace the guides. Which translates to the same work as a worn out head with good exh. valves and springs.
ST dynoed the head with great results. His last dyno was around 390rwhp at 19psi (SFR Stage 2, Sledgehammer and VR007 cam). I have someone else installing the VR003 cam, has the VR big-valve head and S3 kit. I'll ask him to do a run at 1bar, this will show the gains over S3 withou the head and cam. Again, the head and cam must work together!
#35
just in case the answer has changed since last I asked, I trust you use a different maf on the stage 5 kit, compared to the 2.5 liter kits? I'd love to test and tune on the 2.5 before trying on the 3.0L (coming this summer
#37
Originally Posted by fast951
951Obsession, Our MAF & associated software do not care which turbo you have. We do care about the injectors used (55# minimum). The boost characteristics of a turbo can and should be handled to optimize the setup on a car. This is why we offer the PiggyBack. On the chip/board we get you 95-97% on target.
The second car belongs to a buddy and and the set-up is a recent rebuild with little run-time but also has K 27, 55lb, and is running a APE MAF. This is using the MAF chip. That car starts and drives perfectly with no stumbling, stalling, hesitation, or mis-fires. At this point there is no means for signal modification installed on the car as well and is much improved over K27 APE software in every respect. I can't comment how it performs under load but I anticipate it will be very close.
#38
John: I understand the work for you may be the same no matter if the head was new or old it's just that the value for me would be different. Since my head has new valves, guides, etc. it might be in my best interest to find a head that needs to be rebuilt and send it to you for the sledgehammer upgrade. The cost would be the same and I could turn around and either sell or keep the newly rebuilt stock head.
#39
OriginalSterm, The software on the chip/board is totally different than the code on the chip. The software on the board is VERY strict and VERY dead on target (it expects Vin=Vout). We can use the old software on the board, you must request it. But you give up lots of features (semi-sequential, dual maps pump/race gas...).
tconn, Tim the VR003 and VR007 have the same lift on the intake but not on the exhaust. Overlap varies between the two as well.Compared to stock, both cams are designed to provide better flow, more lift more duration than factory... Will make more power!
RK951, Stage 1 turbo (comes in various configurations, all T04E) provides good spoolup, flows more than the K27/6 and does not have the backpressure problems found with the K27/6.
Tom M'Guinn, The Stage 5 (3L) uses very different software than the 2.5L especially the timing. As far as the sensor itself, we can use the 3L sensor on the 2.5L, not a problem as long as the software is for the 2.5L.
#40
Drive-by provocation guy
" Stealth MAF - The MAF sits in place of the stock AFM (between Air Box and J-boot). It comes with Vitesse software, for a true plug-and-play."
John, were you able to do any comparrisons on the dyno/street to see if there is any differnce from running MAF behind the headlight vs. stock location?
#41
SoloRacer, I agree with you. If you have fresh intake valves, seats, guides etc.. keep the head or sell it. The only parts we can reuse (if they pass inspection) when doing a sledge-hammer head are the exhaust valves and the springs.
#42
On the smaller turbos K26, you may not notice a difference. On larger turbos you will notice a reduced spoolup and it may not flow enough for the big HP. A flow bench was used to simulate the flow. No testing on the street was done. The Air box opening is smaller than the 3" pipe we use for the std. MAF kit.
Keep in mind, the "Stealth MAF" was never intended to replace the existing MAF kits. Few people asked for them, we just made it happen.
Also, when going to a larger turbo you have to deal with fitting the J-boot (2") to the turbo inlet (2.75" or 3")..
#44
Good things seem to take time maybe you remember... if not who cares.
There is also an alternativ designed in the mother country of the 951 and even close to Stuttgart...
I really have to admit you do a tremendous job John! Congrats
The restriction of the airbox may be a point - but what about the 100 degree celcuis air sucked in by the con air filter?
kind regards Frank
kind regards Frank
#45
Defending the Border
Rest In Peace
Rest In Peace
PHP Code:
