Boost dropping of 2 PSI
Ok here is the sit rep. The car is an 89 with a K27/6, Autothority MAF and chips along with the typical jetted banjo bolt. This was all part of the PO upgrades. It has low power i.e. 225 RWHP. I have been replacing vacum lines and looking for leaks. I plumbed in a boost gauge last week and it is (or was) making 12 PSI that would drop off right away to a solid and steady 10 PSI. So after getting a straight hard pipe in it, I plumbed in a MBC and dialed in what gives me 15 PSI that dropps off to a steady 13 PSI.
SO...
What is causing the boost to drop off like that? Waste gate? Should I leave it at this setting or turn it up to 17 PSI that drops off to 15 PSI ?
IPSC
SO...
IPSC
Dyno day is coming, the last time it was on the dyno it was running way rich. by 3000 RPMs it was 10 to 1 and falling. Going to trouble shoot that problem one the Dyno hopefully
IPSC
IPSC
the problem with turning the boost up with the autothority chips is that even though they are quite rich in the mid range, they usually lean out up top, so if you turn the boost up the mixture will be even leaner in the higher rpms which will lead to a blown headgasket or worse
IPSC
probably not, I think most autothority stuff is made to run around 15 psi
it would be best if you had a way of tuning the air/fuel ratio, such as a piggyback controller like the SMT6 or S-AFC II, with one of these you can tune fuel curve for max power and reliablity - you could then run anywhere between 15 - 18psi reliably (with good tuning) and make good power.
Originally Posted by IPSC
Is the current 15 PSI falling to 13 PSI dangerous?
IPSC
IPSC
I would tend to think that the chips would be made for the K 27/6 as the came as part of a Powerhaus 100 hp "kit" that they sell. However I am just guessing at this point really.
IPSC
IPSC
