Tial Waste Gate 38mm?
I just brought a tial wastegate and i am wondering do i need the copper gasket?? i heard some people use some people dont. How would it connect to me greddy EBC?? thanks
recent thread on the same topic: https://rennlist.com/forums/944-turbo-and-turbo-s-forum/255242-got-my-tial-wastegate-copper-gaskets.html
How about going to a stainless gasket.
Here's some other gasket options for a TiAL 38mm.
Left - included from TiAL, center - stainless, right - metal fire ring
Basic Sponsor
How much for the metal ones?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
You don't need a gasket on the input side. Really. That’s the way it is made - the valve seat 'floats', so as long as the mating surface is flat don't use a gasket - especially the fiber one.
Chris White
Chris White
Pauerman so what you recommend i should use? also how much and when can you get it out to me? i would like to make the order in today. for the gasket.
Chris White
Chris White
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The stock gaskets typically fail during track use - especially the input side. I would use the exhaust side gasket only.
Chris White
Chris White
chris, is this also true for the 46mm gasket? There is none obviously on the inlet side, but on the outlet side i just have the tial square gasket. As the car is going to see lots of track, will this gasket hold up? Any way to treat it to imporve it?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The outlet side is not pressurized so it is not an issue. When the inlet side leaks it will self destruct quickly because of the hot pressurized gasses.
The exhaust side is fine with the stock gasket.
Chris White
Chris White
