Engine Block # question
Is there any way to tell what year an engine block was manufactured, other than the stamp on the rear, forward of the flywheel? My engine is installed, and there is no way to access the stamp at the aft end.
Here's my problem; I cracked the block in my '89 951, and replaced it. I am having balance shaft problems on the rebuilt engine. When torqued to specs, the top shaft will not turn and tears up the belt, and when left loose enough to rotate, the rear bearings spin and tear up. I have tried 3 sets of bearings including the used ones from the old block, with no success.
My old (89) block is stamped on the aft end, and also has the numbers "0046/3A" and the replacement block has "0046/2A" on it. Is the "2A" an indication of the block being an '86 engine block? If the difference is the year '86 vs. '89, that would make sense, as the balance shaft rear half bearings are different part #'s.
Any help would be appreciated, as I am at my wits end.
Thanks!
doug
Thanks!
doug
When you replaced the block, did you use the balance shaft covers that came with the new block? They are align bored as matching parts and each block must remain with its original covers.
Sam
Sam
The balance shaft covers are from the original 1989 block. The block I got was bare. I don't have the number for the guy I got it from
I guess the fundamental of my problem is: Is the difference between the '86 vs. '87 and up part number for the balance shaft bearings a difference in size? Would that size difference in the bearings make my problem go away?
I'm thinking that I'll just order the '86 bearings from Zims and try them.
Any suggestions?
Thanks again!
Doug
Any suggestions?
Thanks again!
Doug
Basically, what Sam is saying is that the balance shaft covers are an integral part of each specific block. They are not interchangeable. Well, I guess there is a 1 in a million chance they will match up.
I am not sure of part differences, but you really can't even switch within a model year. Maybe there is a way to machine them to match. Your best bet at this point might be to delete the balance shafts.
Back to the original question...
Is the "0046/2A" code on the block indicative of an '86 block?
I cannot get the original upper balancce shaft cover.
Alternative advice anybody?
Thanks!
Doug
Thanks!
Doug
Doug, the covers are bored to EACH INDIVIDUAL block. Even if you find another same-year block, even if it was the next block in the assembly line, it still will not match up!
Sam
Sam
