KLR Chip with Vitesse ?
The Vitesse chip-board does not come with a KLR chip. It just occurred to me that I'm still running an Autothority KLR chip in the KLR. Does it matter what chip is in the the KLR with the Vitesse setup ? I'd like to put the stock chip back in the KLR and sell my Autothority Stage 2 chip set...
Cast Iron Man
You'll want the stock chip if you are running the Vitesse set up. The boost is no longer controlled by the cycling valve which was actuated by the KLR. You are running some type of manual/electronic boost controller right?
Speaking of, Steve, how is your car doing these days? Ready for a rematch? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Regards,
Regards,
Cast Iron Man
Regards,
Regards,
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
I am fabricating my own boost pressure tester to nail down that elusive leak. Once I can get it all the way up to 15 or 16 psi I'll give you a shot. Well, maybe 4th and 5th gear only!
