Question about lean a/f ratio at idle with using Mafterburner
#31
Originally Posted by hally
jy when you get into the throttle, it goes into open loop and onto the WOT maps. So having the o2 sensor disconnected only effects your idle and PT a/f.
Thanks. I had to pull back fueling by 40% at idle to get the KoKeln chips stoich (14.5:1 -14.8:1). This is way more than the sample tune set-up that I was given by LR for my 951. Granted, they said I would have to modify their curve, but I didn't think it would be that much. Like I said before, KoKeln chips run pig rich, and I have to question the programming. At some point, I will get rid of the KoKeln chips, but I will compensate (for the richness) with MAFterburner for the moment.
#32
Any other ideas? I guess I'm stuck. With the fqs set at 0 for stock injectors and the Mafterburner set at 55lb injectors the car idles at 14.7:1 for 30 seconds or so. It will then go lean to 20:1 and I can't richen up past 16:1 before I run out of adjustment range. Is it the programming in the chips that is causing this?
#33
POR951turbo: Check your fpr. You may not be getting the correct pressure at the rail. Or the fpr is going south.if it checks out ok. You could also try setting the injector size in the pb to stock injectors 39's or what ever and follow the instructions below.
JY951: You should lower your fuel pressure so you don't run out of calibration on the pb.
#34
I just spoke with Wes at Lindsey. He states that we shouldn't be using the injector selector in the Mafterburner software. Apparently the software was designed for a NA car and the larger injector size of turbo cars causes the tune to run out of the range of the scale. I'll change my fqs switch back to 1 for 55lb. injectors and set the factory defaults back on the Mafterburner. This should give me enough range in the scale to richen up the idle.
#36
#37
Keep in mind that part throttle timing gets corrupted to some degree if shift the sensor voltage to compensate for larger injectors. It breaks relationship b/w voltage the chip is seeing and actual flow which messes with the chips calculation of load, which moves the lookup point on the part throttle fuel and timing maps.
#38
Lean at open throttle
I have #52 marren fuel injectors 3.0 fuel regulator Lindsey max chips burned for the super 48 turbo and #55 injectors. I got the DME and KLR with the chips and the turbo. Ran great until i opened the mafterburner program an changed the injector sizes to what was in the car,it has not ran correct since then.I have got it close but it runs good at idle but when opening throttle it goes to lean to drive and seems to be staving for fuel A/F idle 12.5 pushing the gas pedal it heads of the scale A/F 13 to off the gage. cant get support but all company's say the have the fix buy there products. looking into rouge upgrade thru Lindsey
