BOV vacuum line
BOV vacuum line
What king of vacuum line do you all run to the bypass (aka BOV) valve? I still have the stock skinny black plastic line but was going to replace it. Any opinions? Does it matter?
lindsey racing sells a great vacuum line kit. http://www.lindseyracing.com/Merchan...=944VACUUMLINE
Im pretty sure about 90 percent of rennlist is using it. You should too.
The Lindsey kit is an excellent choice, I have been impressed with all their products to date. For vacuum lines, I went down to NAPA and ordered their high-temp silicone hose. Specs say its good to 375 degrees F, and used brass T's to make conections. They also were able to order extra small spring clamps for all the connections to be sure nothing came loose under high boost levels. Whole setup cost around 15 or 20 bucks, including the 50' roll of hose. I had everything the next day, and have had no trouble with it so far. Just thought I'd share.
Well I just used rubber vacuum hose for the time being. My 20 year old factory plastic lines were more clogged than Dom Deluise's arteries, so I wanted to put something new in there. PepBoys had plastic looking boy-racer tubing in neor colors, which they claimed to be silicon, but I figured I'd wait. Napa is a good idea -- they tend to have access to better stuff.
6mm samco hose here to the BOV. The LR product is a little thin in gauge, especially if you are having issues keeping the valve open.
Hi NZ! fyi the hose it .100" thick
Wes
Wes
UAE Rennlist Ambassador
LR Silicon
Note: I believe Lindsey changed the hose OD, i got the vacuum kit last Jan (2005) and when i ordered a new batch (late Jan 2006) the new batch had a thicker OD.
Yikes! A simple "I'm not Andrew, NZ, AMAF, or anyone else people think I am." would suffice.
Back on topic, www.hosetechniques.com offers good tubing in bulk if you want to piece together your own kit.
Originally Posted by stewardx
No problem. just wanted to say hello Andrew!
Wes
Wes
