Piston Squrters for a 3.0 turbo block
I am just about to put together a 3.0 turbo block but I need some piston squirters to install in the block as it came without them. Does anyone have any experience of this, and any recommendations on where to buy the 968 part which is not available through Porsche. I am told I can use the squirters from a 964 or 993 which are different lengths, has anyone tried this?
Are there any pros and cons to going with or without the piston squirters?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Piston squirters are available form Kelly Moss….if they feel like it!
You won’t get any installation instructions….
Not a fun job.
Chris White
Not a fun job.
Chris White
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I reread the message – do you mean that the holes are there but somebody removed the squirters or that you have a 3.0 S2 block and you need to drill the holes? (S2 blocks did not have the squirters – only the 968 blocks)
Chris White
Chris White
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Originally Posted by nick_968
Any tips Chris, how do you seal them into the block?
The squirters are trapped in place, the main bearings will prevent them from falling out! It should be a close tolerance fit.
Chris White
It is a 968 block, and as such has the holes for the squirters, but no squirters installed. Its a brand new block, I guess it was a from batch of parts that didnt come through the normal Porsche route and therefore doesnt have the squirters. It has the siamesed cylinders and cross hatching as well.
This is a picture of the factory installed oil nozzles in the 968 block. I don’t know if they are threaded or press fit in the holes. Interesting to now that this block comes without them.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Press fit – the squiters are smooth bore with a flange on the bottom end.
Cost to install? The squirters are about $50 each plus figure a couple of hours of machining time ($150) and shipping….it gets expensive pretty quickly!!
Chris White
Chris White
That really isn't too bad if you are having a bunch of other machine work done.
Do you think the results are worth the cost? It should reduce the chances of pre-ignition, correct? Is there any downside other than cost?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
