Where can I get IC end tanks from?
Drive-by provocation guy
Since the end tanks are for our car, and not jsut the core you are aksing about, then I would say you would need a 951 IC.
You are correct Tim. Although I was just thinking I can possibly just cut part of the inlet and weld some aluminum pieces to make the inlet flow better.
The core doesn't flow much better than it already does... even with a straight funnel attached to the end of the core,you'll maybe see 10-12 cfm @ 10" more than the stock item.
I was thinking about doing the same thing, but since you said it wont gain much. the new questions is where can a get a decent core and endtanks to make my own IC?
yea, I was gong to sa ythe same. I would think with all that work you might as well upgrade the core as well.
I have seen heat exhangers on the net. As soon as you call it an IC, the price gets jacked up.
