CV Joint Grease
I want to clean out the joint grease while I have the tranny/axles out.
The boots are in fine shape so all I need is the grease that comes in the cute little packages. Where can I get this stuff? The local parts stores say you get it when you buy the boots but don't sell it by itself.
I got mine, exactly like you explained, in a cute little package, at my local auto parts store. Maybe call around a few places? Theres gotta be some auto parts store with CV grease near by.
I use Redline synthetic grease but you may have to order it. Call some race shops in your area.
I have used Valvoline synthetic grease that also states on the tube that it is suitable for CV Joints. It is no longer available at the local auto parts store. DO NOT use any grease, such as Mobil 1 synthetic grease, that does not state on the package that it is suitable for CV Joints.
I've used Redline as well with good results.
f1rocks, how old are your boots? If they're more than, say 5 years, I'd go ahead and replace them while you have everything else off. Most boot kits also come w/ the cute little grease packs so you'd acquire those as well.
for future reference
http://www.paragon-products.com/product_p/rlcv2.htm Redline moly grease
http://www.paragon-products.com/product_p/swepco101.htm
Both from Paragon.
Both from Paragon.
I have a small rip in my rr cv boot, and some resulting clicking in the cv. As a temporary fix, can I squeeze in some grease in the boot and seal it up? Where do you have to put the grease?
Dismantling CV joints and putting them back together is an unholy pain in the ***. You need about four arms to do it, and more patience than the Budda.
yeah I know I should just replace the axle...seems TONS easier than repacking CV's. What is the tool you need....12mm cheesehead? 350ft/lbs torque? Seems like a really easy job to swap axles
If one of them rounds out, Sears carrys Bolt-Outs (or Easy-Outs, I can never remember which is which). Its a set of things that look like sockets, but inside they have a spiral teeth setup. You hammer them onto the nut, bolt, whatever, and twist with a wrench. Theyre one of the best investments ive made in tools.
