Forgot to release my auto-tensioner spring and started her up.........
Old 01-02-2006, 07:58 PM
special tool
special tool's Avatar
Default Forgot to release my auto-tensioner spring and started her up.........
Just got done a LOT of head work on the sledgehammer head - springs, cam, belts, etc.
Well I roll it over several times by hand (of course) lines up perfectly.
Go to start her up rrrrr-rrrrr - rrrreee- rrrreeee.................uh-oh. What did I do in my haste????? (occasionally I am hasty on my own stuff )
Walked to the front of the car - OH SHIIIIIIIT!!!!!!! tensioner is all the way to the right!!! Not good!!!
So I am thinking I just screwed up John's beautiful head (worst part would be him busting my *****). Not really the end of the world anyway because I can fix it just as fast as Perry951 or skunk
So I put in the compression tester on #1 first....30 psi....
I then start to strip it down.
I get the cam tower off and I notice that all the valve tops appear to be in a flat plane???? WTF????? (potentially good news, but NO WAY in hell)
I now get out the leakdown......
ALL 4 88-89/90-91????????? How is this possible - it jumped at least 3 teeth and ran on one startup for a second or 2.
Just thought I share a glimmer of hope - still can't believe the luck.
Keep in mind here - this cam has BIIIIIIIG lift and my intake valves are like silver dollars - some of you guys can appreciate what these 2 factors contribute to my strees...
Old 01-02-2006, 08:02 PM
TRWright
TRWright's Avatar
I just want to know one thing:
How can such a knuckle-head make so much horsepower?
Old 01-02-2006, 08:03 PM
Skunk Workz
Skunk Workz's Avatar
Deja vu...or maybe I should let Thomas (Black Arrow) have the honors...
special tool
I will concede knucklehead on this one.
Old 01-02-2006, 08:06 PM
Turbo944T
Turbo944T's Avatar
Bwahahahahaha I love the open an honest confession. You are the shizzle beeeeacha.
Old 01-02-2006, 08:07 PM
Skunk Workz
Even the best f**k up once in a while....
Turbo944T
Turbo944T's Avatar
You could rename it the knucklehead cam?
Old 01-02-2006, 08:10 PM
special tool
sledgehammer head and knucklehead cam.....awesome
Old 01-02-2006, 08:17 PM
Techno Duck
Techno Duck's Avatar
ST, i did the same thing on my car, just i was turning it over by hand (so i guess not THAT bad!). But the belt slipped atleast 3-4 teeth before i realized i was an idiot and did not set the tension right (or tension it at all for that matter). It was pretty nerve racking trying to get the crank and cam all lined up again. I must have turned over the motor by hand 100 times to verify everything was setup correctly before i started the car.
Old 01-02-2006, 08:20 PM
jlturpin
jlturpin's Avatar
Hope that luck is in your corner today. From the results of your leakdown on a cold engine you should be good, as you know. What was up with the 30 psi on from the compression test?
John won't even get to read about this for another 2 weeks so your "sac" should be safe for now.
Old 01-02-2006, 08:32 PM
special tool
Yeah the head is definitely fine.
The 30 psi cranking pressure is from cam timing being off so much.
Old 01-02-2006, 08:41 PM
jlturpin
jlturpin's Avatar
Great news. Delete the post before John returns .
Old 01-02-2006, 08:42 PM
evil 944t
evil 944t's Avatar
Good thing those valves are cheap. Hope all is well.
Old 01-02-2006, 08:43 PM
lart951
Basic Sponsor
lart951's Avatar
This is not the first time lutjen, you told me the same thing happened to you with rolex's car
Old 01-02-2006, 08:53 PM
Turbo944T
Turbo944T's Avatar
That explains the dyno run being how many months overdue now?
Quick Reply: Forgot to release my auto-tensioner spring and started her up.........
