Replacing Airbag steering wheel w/ non airbag
Thanks for the input- yes, I know the horn ring isn't needed- that's what I'm saying- I stacked mine in w/the spacer- I've had it this way for two years... It would not allow a ground though, so I had to sand off paint on the surface sides to use my horn- but that was teh least of my probs on getting a horn- that was a BITCH! Anyway, why I had asked about being able to get those bolts in was b/c I probably only have 2 or 3 threads engaged in mine- I mean it's really barely in there- always kind of worried me a tiny bit, but they've held for a long time now- I guess I'll see how the 25mm one is when I get it... Maybe I should have gone ahead & ordered black & not had to paint though... hmmmm... I guess it doesn't matter- I have some black paint I used to touch up my horn ring outer edge- it matched well- your black spacer looks a hair light, although it's no big deal & it might just be the light of the picture... Is Santa Rosa in hte Sonoma County area? I have friend's there- I love wine country... Wish I had a real job/life & I'd probably be there instead of here...
Yeah, Santa Rosa is smack dab in the middle of wine country in Sonoma County. Beautiful driving roads for the Porsche out here :-) BTW, if you want longer bolts for piece of mind, try McMaster-Carr (www.mcmaster.com). They have those tapered bolts in many lengths. They are 5mm bolts.
link:
http://www.mcmaster.com/param/asp/ps...=286;255=22663
link:
You're KIDDING!!! You have no idea how many places I looked to try to find longer bolts that matched those- I'm assuming these are allen head too...??? That's nuts! Thanks for the link- I'll check it tommorrow... I ordered the 25mm spacer, so I'll see how it fits next week sometime. IF I decide to add the horn ring then I gueuss I'll have to order some from them... that'll be fine... I just know that at some point I wont be able to reach the turn signal & the wheel is getting too high too- I want to bring it down slightly- Actually wanted it slightly lower than stock & right now, it's probably at least 20mm higher- the Momo is 30mm smaller so that raied it 15mm right there.. then the angle as it gets closer to me... I know there's a way to adjust it up to ~1/2" but I don't know how... anyone??? Also, i'm wondering if I should have just ordered the black 1" spacer instead of silver- now I'll have to paint it's outer edges... oh well... Thanks Brad...
The last link I posted doesn't work... try this one:
http://www.mcmaster.com/nav/enter.asp?pagenum=2975
This is page number 2975 of their catalog. They have stainless ones on page 2976. You are looking for size M5. You might have to buy a box of 25 or 50 or 100, but they are not that expensive..
Wow guys
I just took out my cluster to change the light bulbs in it, and I got the idea of going ahead and replacing my stock steering wheel (airbag) with a momo wheel. Didn't think that this could be so involved. My car is a 87' 951 w/airbags (the airbag control unit thing...which sits behind the passenger side glove box is not working. This is why my warning light and airbag light are always on.
If I dont even use spacers....what am I going to need?
What I believe I'm going to need if I am not mistaken would be the following:
Momo Steering wheel of choice
Momo Hub adapter
Combo switch assembly
Is the switch assembly a absolute must that I need to buy? My current turn signals/wiper switches are working perfectly fine.
Momo Hub adapter
Wow guys
Momo Hub adapter
Momo Hub adapter
Thx for the reply.
The switch cluster you are referring to is the part they are calling the "combo-switch" correct? Yes, I also read on 944online that I would need the "non-airbag" switch mechanism. So would any years 951 switch work fine on my 87'?
I read on the 1st page of this thread that the airbag combo switch can be modified with the addition of the horn contact piece (928-652-104-00) to make the horn work. Is this easy to do?
Thx for the reply.
I don't know about swapping the horn contact piece, never tried it myself.
I missed the note on this- I've done a Momo in 88 Turbo S- did not have the contact switch, BUT, some airbag cars DO have either the hole OR the hole w/the tab itself. You do NOT have to buy a new assembly either way, though- I did not- I simply drilled a hole exactly where the tab is supposed to be & put it on- worked fine. Ski's link is a great place to start as Tom Pultz has a great write-up on it & my car was one of two that he had written about, way back when, when he mentioned that SOME of the later cars did not have the contact switch (OR hole) & others did... I believe his sons car is an 89 & it DOES have the swtich OR at least the hole to mount hte switch into... That switch is only a few bucks...
good luck
good luck
I have an 88 944 turbo w/airbag and I installed a sparco wheel. My horn is now a wire that I have to connect to metal on my column but I keep reading about drilling a hole in the cobination switch to pull the wire to the horn. I would rather not buy a $150 switch if I could drill a hole and contect the wire. Can anyone that's done this show pics or where I can find them? Or where to drill the hole, etc..etc...
Thanks in advance.
Thanks in advance.
I have this thing: http://www.jwesteng.com/porsche/steering.htm and I love it. It only spaces the wheel out 16mm, but it moves it up 12mm as well. I can barely notice the eccentric rotation, but I can definitely notice the extra room/comfort while driving. I'd heavily recommend it.
For models that came with an airbag - This is the connector piece that is needed! - https://www.porscheatlantaperimeterp.../N0175994.html
