CA Smog Test Results
For reference purposes for others here, my '87 951, motor rebuilt 5k miles ago and stock except for Guru chips and Reliaboost just posted the following CA smog results (thank God!) Note the NOx figure at 25mph !!
HC CO NOx
Test rpm CO2 O2 Max Ave Meas Max Ave Meas Max Ave Meas
15 mph 2460 15.3 0.2 116 31 40 0.74 0.10 0.09 791 237 631
25 mph 2399 14.9 0.3 91 20 26 0.62 0.09 0.07 730 199 727
HC CO NOx
Mexican Ambassador
those are all pretty good, brad. i want to take my car to a smog shop just for kicks, just to see what the numbers are. just so i can see the smog man cry. no cat? dumped wastegate? my car is the anti-smog. all i need now is a lopey cam.
Juan, yeah, the CA smog situation is not kind to us 944 owners. Gotta say that your dumped wastegate sounded pretty cool when you blew past us on hwy 50 last weekend !
Mexican Ambassador
Hey Man
Glad to see everything is environmentally friendly with your car Brad. I have a car that passes smog with chips., 3-bar FPR with pretty good numbers; but the same car will fume you out if you are behind me on a climb. Meanwhile at the oasis the AF ratio is fine. I've decided that every 951 blows a bit of raw gas and smoke under hard boost and just get used to it. Am I wrong?
On the last ride, Josh was riding behind me for a while and commented that mine was the only 951 that wasn't belching stuff under hard boost... Or maybe I wasn't driving hard enough
Hey Man
You know, I'm not sure about that. I think it depends a lot on the chips you're using. Obviously Danno's Guru chips work with the 3.0-bar FPR to ensure that at low engine speeds, low-load and idle conditions, the fuel delivery is kept in check, as shown by my low HC numbers.
On the last ride, Josh was riding behind me for a while and commented that mine was the only 951 that wasn't belching stuff under hard boost... Or maybe I wasn't driving hard enough![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Oh good, for a minute there I was thinking there was something wrong with my car. Good to hear it smokes like the rest of them - means its not burning too lean...
Mexican Ambassador
I gotta say I guess I missed that; I don't know how, but I didn't see the pearl car at all after we left Sunrise. All I heard were stories at the 1st pullover. The rest of us got our chops in later on in the day.
