light show under bonnet - shouold i buy these wires?
While on a test drive tonight after changing my radiator thermo switch i noticed a few little sparklers going off when under the bonnet, one particularly was pretty constant arcing onto the fuel damper. Anyway these are the wires that paragon have on their website, they have stock beru connectors and are 8mm vs 7mm stock. Not sure what brand wires they actuall are. Anyone info on them? cheers Gregor.
http://www.paragon-products.com/product_p/kb_09-566.htm
I would highly recommend Magnecor wires. I have them on both my 944's and they are a high quality wire with great EMI supression. Can be had for $65-$70 too for the KV85's. Do a search for Magnecor. I bought both of my sets straight from Magnecor direct.
http://www.magnecor.com/
http://www.magnecor.co.uk/ -- here is a United Kindom factory as well...might save you on shipping, but you will have VAT.
Be sure that what you think is a lightshow is not just the underhood light coming on, and reflecting off something. To be sure, remove the light bulb and go for another test drive.
Otherwise I second magnecor wires, but ignition wires seldom go bad on 944 turbos, cap and rotor are far more common. If you are replacing the wires, almost any basic 7mm will do, no need for fancy 8 or 9 milimeter red wires etc. Also, magnecor wires are nice but the boot that will be sold through them is not a perfect fit.
Ahmet
Ahmet
Originally Posted by hally
...constant arcing onto the fuel damper....http://www.paragon-products.com/product_p/kb_09-566.htm
This could be a fire hazard. Change ye wires.
I like the idea of having stock beru connectors, need to be rugged and plug and play. That lindsey magnecor with beru connectors looks good horsom.
will go a stock boot ta
