View Poll Results: Which one?
GT30R
19
65.52%
GT35R
10
34.48%
Voters: 29. You may not vote on this poll
Ok, going to buy the new turbo this month, GT30R or GT35R?
Old 10-10-2005, 12:58 AM
  #31
NZ951
NZ951's Avatar
Corleone, I have talked to a guy local that I trust and he is suggesting the GT35R with .68 housing... I am thinking that could be the way to go...
Old 10-10-2005, 01:52 AM
  #32
J Chen
J Chen's Avatar
Andrew,
Better choice is to go with GT30 turbine in .68 hot housing
with GT35R cold side.
Old 10-10-2005, 01:54 AM
  #33
NZ951
NZ951's Avatar
I dont think you can config that... basically the only choice you get is the exhaust housing a/r!
I am really confident the GT35R in .68 is the way to go.
Old 10-10-2005, 04:03 AM
  #34
NZ951
NZ951's Avatar
PS what are people using for lb/min on compressor maps these days? Around 32lbs?
PS will the T04S cover fit under the stock manifold?
Old 10-10-2005, 05:57 AM
  #35
Duke
Duke's Avatar
..what the xxx is going on... I could swear I replied here an hour ago..
anyway...
How about a GT3040R? I think it might be what your are looking for... it uses the big 40-compressor found in the GT35 but with the smaller turbine wheel of the 30. IMHO I think it would work very well for higher boost applications on our engines.
Old 10-10-2005, 09:04 AM
  #36
J Chen
J Chen's Avatar
Andrew, like the TO4S GT25 that I'm using, besides
making a turbo mount, there will be a need to cut
of part of the engine mount as well. Since you no
longer have AC, you should not have clearence
problem with the alternator. Unless if the alternator
is still in the original spot you who then have to
reposition it.
Old 10-10-2005, 12:54 PM
  #37
Joseph Imports
Joseph Imports's Avatar
IMO- For a 2.5L with stock internals and no modifications to the head or block, the GT30R is probably the right choice for quick spool and impressive HP. The Gt35R for 2.7L + or head mods.
GRT-TBO-005 Garrett GT30R
Turbine_AR: 63
Specify_Turbine_Housing_Style: K24_K26_Style
V-Band_GT_Option $50.00
Total: $1,400.00
Alex-
Old 10-10-2005, 02:11 PM
  #38
944CS
944CS's Avatar
what about that Vitesse stg.3 that you have on your wish list?...
Old 10-10-2005, 03:48 PM
  #39
NZ951
NZ951's Avatar
I dont actually know anyone using a GT35R... I would not mind being the first to find out what its like! Worst comes to worst, I can just sell it. My car is not quite stock, and I think I have enough gas to push the wheel.
Duke, I thought the GT30/40 had a smaller turbine also?
Old 10-10-2005, 04:33 PM
  #40
Duke
Duke's Avatar
Yes that was what I wrote, or how do you mean?
Old 10-10-2005, 05:48 PM
  #41
Joseph Imports
[QUOTE=Machtig Turbo]I dont actually know anyone using a GT35R... I would not mind being the first to find out what its like! Worst comes to worst, I can just sell it. My car is not quite stock, and I think I have enough gas to push the wheel.
QUOTE]
Go for it! Lets see what it can do!
-Alex
Old 10-10-2005, 09:55 PM
  #42
NZ951
NZ951's Avatar
Sorry Duke, I meant compressor...
I just spoke with Tim at SFR... I just need to determine if I go E or S cover now... all depends if I can get my *** into gear and sort a manifold.
Old 10-11-2005, 01:49 AM
  #43
DFASTEST951
DFASTEST951's Avatar
Quote by Corleone...
"I can say if you have 500 crank hp in our cars it is a lot, it is a huge difference than having 350 (which is a lot easier). There has been a lot of inflation in hp talking, how many of us have tried a well tuned 951 with a driveable 500 hp? Its really a lot and its a very fast car. Here in Sweden many talks of their hp´s and when they go to the dyno its often a lot less power than they expected and there is also a lot of dynos that dont are calibrated and makes this even worse. The thing is to have that amount of power that you want with so little in boost as possible and with good timing advance."
I have well over 500 hp and my car drives and idles better than stock and just passed emissions today without a cat.
Old 10-11-2005, 02:12 AM
  #44
95ONE
95ONE's Avatar
So Machtig. Are you going with the T4 Turbine with the V-band?
I'm new. Sorry for the interruption. I know you don't know me, but I sell a lot of Turbos. I work in a performance shop in Houston. I just bought my 951 a few months ago. And I plan on using the GT35R.
I can't wait to see your results.
One last thing.. 12,418 posts? ..... Damn..... ......
Old 10-11-2005, 02:39 AM
  #45
NZ951
NZ951's Avatar
Yup I am getting the V band option. www.speedforceracing.com sell a 3" downpipe to mate it bolt on to the outlet.
What config GT35R are you thinking? .63? What cover?
The S cover wont fit under the stock manifold, the E cover will... though that means going from 4" intlet and 2.5 outlet to 3" inlet and 2" outlet...
Quick Reply: Ok, going to buy the new turbo this month, GT30R or GT35R?
