Paging engine builders:
UAE Rennlist Ambassador
Originally Posted by Konstantin
have you or anyone else ever saw a writen document where Porsche say that you must replace them?
I never saw something like this but I heard from others many times
Konstantin
Konstantin
Spell Checker
Originally Posted by Tom M'Guinn
What spec would you be measuring against? Porsche says to throw them away...
Konstantin
Konstantin
My car is at a dealer for a blown HG and they have not said anything about having to replace the head studs. I have thought about it though and I will ask them tomorrow.
1 Post
Ok a bit more OT but what about O ringed and ARP studs? Retorque or not? When I put the head on last week I torqued them down and then loosened and retorqued them to ARP specs (65 ftlbs? I think)
Originally Posted by badcoupe
Update. yes you need to retorque as I gambled and mine blew after about a half hour of driving
Hmmm, if you blew if out after half hour, you have to wonder if something else was wrong? Is the torque wrench new or recently calibrated? Raceware says to fully heat cycle it before re-torquing, and I know some builders recommend several heat cycles (up to 1k miles).
"Because the head gasket will compress upon initial torquing, make sure studs and bolts are re-torqued after the engine has been run."
I used a MLS gasket, ARP headstuds and did not re-torque as the MLS does not compress.
yeah I ran a it a bit and finally drove it today for the first time. the nutas weren't at proper torque when I took it apart here's a pic of the gasket
