3inch exhaust goodness
The top portion of the downpipe directly out of the turbo came from speedforceracing. I know my limits, and i saved myself the headache by having tim make that part of the exhaust, from then on we've been making the exhaust ourselves. Check it out, not bad for a stick welder.
Originally Posted by 1FastRedSC
Yeah, tim is an excellent welder, his stuff costs a lot, but if i did a close up on those welds on the SFR downpipe, you'd understand why.
Yes, 304 to be exact. Actually we are really going at it today, it might be done, last thing i need to do is line up the merging area of the wastegate dump pipe to the main exhaust. And yes, it's even harder than it sounds
Originally Posted by David Floyd
Balance shaft delete I see
Originally Posted by tedwright
Are you just going to cut the WG tie in off the stock exhaust and then weld it into your 3"? I would think that would be the best approach.
Yes sir, pauter rods, knife edged crank, JE pistons, all balanced. So no more balance shafts. .
You just described my engine
Nice work on the exhaust.
