TPS install trick
TPS install trick
Throw away the 2 phillips screws that mount the tps. Replace them with stainless allen/hex head screws and flat washer, used a mild locktite. Take a dremel tool with a cutting wheel and change the bottom tps screw hole into an open slot, big enough for it to slide around the allen. Install the bottom allen screw/washer first before installing the tps onto the throttle body and then just rotate the tps onto the allen screw.
You work too hard! After a bit of cussing, story here I just put the top screw in and moved on...tons of miles later still fine.
WELL I must admit, u are probably right. I am just one of those people that can't stand to leave that screw out, many times I wish I was different, I would have more time to "grip it and rip it".
I am very attentive to the details and am the same way....however this one item pushed me too far and I had to live the rest of my life....on the edge with one screw missing
Mexican Ambassador
Originally Posted by eniac
Why not just remove the TB? Only 4 easy to get to bolts hold it on.
Originally Posted by 951Obsession
eniac is right, there's more than one way to skin a cat......or a TPS for that matter,
Mexican Ambassador
Originally Posted by Tom M'Guinn
I never understood why anyone would want a skinless cat.
