fuel tank
fuel tank
The other day my car started to stutter like you were stalling even though i was at 3k in 2nd. It wouldnt hold a steady idle and so i put a 2gallons in and the car ran fine. So then i went and put another 14gallons in. I know i was on the reserve but if im figuring right i should still have had 5 gallons left. What do you think is wrong. I was thinking its just gunked up and cant suck the rest out. I going to try and use chevron techron fuel cleaner maybe it will clean it up some but has anyone else ever had this problem? I dont know if the previous owners ever took it to the reserve could that be the problem? Other than that the car runs great changed the spark plugs, wires, distributor, and rotor. Any help would be nice. Also i just ordered a boostsciences reflex divertor valve and was wondering how loud it really is?
I can't figure out your math, but are you implying the fuel system got clogged because you ran out of fuel?
I guess it's possible, but I've never heard of it. Any sediment that would be disturbed would go the the fuel filter, so that's the best place to start. You probably need one anyway.
What's the purpose of the divertor valve?
i tested the old 84944 fuel lite, which wasn't hooked up and the bulb was bad and ended up barely getting home with all the garbage that was sucked into the fuel filter on my little test.
changing out the filter had me back on the road.
87951
I dont think i explained right. Basically what i was trying to say was that i had another 6 gallons left but couldnt use it. But after i filled up the car runs fine no problems at all. Maybe this will help. The diverter valve is a bypass valve that boostsciences sells and i was wondering how loud it is. Should u here the stock bypass valve cause i never really here it. Sorry i didnt explain correctly.
Its the blow off valve for the car. But it isnt actually a bov since our cars dont release the pressure into the atmosphere. I think on our cars they are called bypass valves. Heres the link to the site http://www.boostsciences.com/reflex.html
terminology. these cars do have bov's but you're talking about the fuel system, right, thats where you started this post.
still don't know where this goes. the site doesn't say, just that everyone needs one and please send $129.
87951
87951
