To all with magnetic drain plugs . . .
. . . do you see ferrous particles on them when you change your oil?
I notice that the very sharp 90-degree edges of mine become mushroomed. I will probably send in my oil for analysis, but this is all a bit alarming.
I had a bit of inner valve spring on mine once (in my S2 cab). When we pulled the cams it turned out it was debris from an old failure but we could see where the broken spring had been from marks on the pocket.
Basic Sponsor
I remenber once when i did my oil change I notice little chunks on my plug too, a week later KABOOM a broken ring and $ 7000.00 worth of rebuild. Not trying to scare you hope it helps.
UAE Rennlist Ambassador
Nothing at all here on the 951
My NA has huge chunks the first time i changed the oil since ownership, but never had a problem since (ran 2+years fine).
