Second oil cooler or larger oil cooler ?
or you could go with the single larger setup like a couple of us on the 'list did.we went with an 2nd gen rx7 oil cooler.here are some pics,if you want info on it there are a few threads on it on the turbo boards.HTH
![](http://img.photobucket.com/albums/v139/shortyboy55/porsche/DSC02546.jpg)
![](http://img.photobucket.com/albums/v139/shortyboy55/porsche/DSC02545.jpg)
Did you retain A/C with the rx-7 setup?
I am most interested, just haven't had the time to read the threads yet. I think that is what I will do on my 951 eventually.
yes you can still retain the a/c.those pictures are quite old,(still had a/c back then,as you can still see the condesor)but i just recently took off all the a/c components.i got my rx7 for dirt cheap from a local guy($20),then i needed to order some AN fittings for the oil cooler(mazdatrix.com),then i needed some AN fittings for the oil cooler housing(batinc.com)then run you SS braided lines and mount in the front of radiator.ill probably move the oil cooler more back since theres more room now.hope this helps
-wayne
-wayne
I run an 89 Turbo E stock car in PCA club racing, its also a daily driver. I fitted the supplemental cooler from Terry Morris trymorris@***.net. It fits behind the drivers side fog light, and connects to the existing oil coller pipes. To add additional cooling holes are drilled into the foglight cavity. During the racing season I run with the fog light out. For winter I put the foglight in. Its a simple install and doesn't require any cutting. I removed one of the horns to get more space. I ran Texas motor speedway which is flatout on the banking, at over 100degrees with no problems. It may not be the best setup, but its cost effective, and works, I would have no hesitation recomending it.
Regards.
Raj
Do you guys that are covering the front of the radiator with a large oil cooler, notice the coolant temps higher than before?
Looks like a great setup for oil cooling, but could noticeably reduce the efficiency of the radiator(?).
Originally Posted by Duke
sweet, so the mocal you're using has an inbuilt thermostat?
Originally Posted by Ski
Twin setup on the track car, pic
[IMG]http://forums.rennlist.com/upload/twincooler.jpg[/MG]
[IMG]http://forums.rennlist.com/upload/tandemcoolers.jpg[/MG]
Track temps are good and our extra temp sensor is in the turbo drain, so that's warm. On cooler track days, we average around 250F, warmer summer days we average around 260-275.
Originally Posted by Zero10
With the oil cooler out there, does it effect the A/C's cooling ability?
Just want to be sure that there are no hidden downsides before I start sourcing parts![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Do you need A/C up there in the Great White North
