Forge CBV installation
1 Post
Originally Posted by TRP951
I am just about done putting my car back together i have some tubes that might work so if they do i will post a pic for you and tell you the part number if you want so you can fit yours. I have a vitesse MAF also so it should fit the same
Please keep me updated.
here is a pic of mine sorry for the glare its very sunny out and i took the photo with my camera phone.
I used the stock 90 degree elbow on the top and shortened it a little, and I used a S shaped hose on the bottom alot of trimming it to shorten it up a little to clear the hood cause its close on my car.
Basic Sponsor
Originally Posted by David Floyd
this is my setup
I thought the BOV releases the excess boost from the intercooler pipe to the maf intake after you cut off throttle?
1 Post
Basic Sponsor
Originally Posted by schnellfahrer
That's right. Your setup should work unless the spring is to weak stay shut until vacuum is applied to the top port.
Basic Sponsor
Originally Posted by special tool
Lart - turn yours around to be like David's.
Basic Sponsor
In the bottom picture the valve is on backwards
1 Post
It should work in both orientations. When you install it backwards (like in the last picture) you will have boostpressure on the valve which may open the valve and bleed of boost. This is not good.
If the spring is strong enough. this should not be an issue.
In theory, when you are under boost, pressure is applied to the top port, keeping it closed.
Special Tools suggests you install it the right way (top picture) just to be sure you are not bleeding off boost prematurely.
