camber plate snapped!
Originally Posted by dagame27
Yes my rear shock did throw the bolt. I have read of other occasions where this has happened with these and other coilover rear shocks. By the way since you'd have to be an absolute moron to install the plates wrong. I suppose you are calling me a moron for not noticing right?
The reason I called your mechanic a moron is simply because he is a professional. As a professional, this simple task should not get botched. I am not even certain how he could have installed it that way with our cars. Was he familiar with 944s? I would seriously question his skills.
The other examples posted where the camber plate is installed on top is for cars that have stock shock mounts on top as well. The tops of our shock towers aren't even close to flat. Take a lock at ridge around the opening:
How would you tighten it down? I stand by my comment that he is a moron.
When you say "throw the bolt", do you mean it backed out and fell out or do you mean it sheared or snapped?
