What is an aftermarket coil good for?
Old 06-21-2005, 03:05 AM
Epic2112
Epic2112's Avatar
Default What is an aftermarket coil good for?
Just what the title says: what is better about an aftermarket coil than the stock one (MSD Blaster or whatever), and do I need one?
Old 06-21-2005, 07:47 AM
awilson40
awilson40's Avatar
"absolutely nuthin...Huh, Say it again... "
Really, I noticed no diff between stock and a blaster
Old 06-21-2005, 08:43 AM
streckfu's
streckfu's's Avatar
Inoticed asubtle difference but then, I was using Magnecor wires and hadpretty fresh plus, cap, and rotor. The idle felt a little more stable and it reved just a little easier. I think there was a small improvement.
It's not that expensiveso give it a try.
Old 06-21-2005, 10:33 AM
Porsche-O-Phile
Porsche-O-Phile's Avatar
Aftermarket ones help your beer from tipping over better.
Old 06-21-2005, 11:26 AM
Epic2112
Epic2112's Avatar
Ok well let me put my question a bit differently: what are aftermarket coils supposed to be good for?
Old 06-21-2005, 08:32 PM
Epic2112
Epic2112's Avatar
Surely someone must have some idea...
Old 06-21-2005, 08:35 PM
streckfu's
streckfu's's Avatar
Increased spark energy due to a larger voltage. 45kV for the MSD while the stock coil is rated at 30kV. The increased spark energy is supposed to provide a more efficient combustion.
Old 06-21-2005, 08:40 PM
fast951
fast951's Avatar
Stick to stock coil. Some high energy coils do a job on the cap & rotor.
Best approach is to convert to wasted spark with coil packs or coil over plug. In the past you had to go to standalone for this type of conversion. Soon, you will be able to do it with the Motronic
John
Email
www.vitesseracing.com
Old 06-21-2005, 08:43 PM
streckfu's
streckfu's's Avatar
Does this mean you will be telling us more about this ability in the near future?
Old 06-21-2005, 08:44 PM
WesM951
WesM951's Avatar
I have the nology coil, i noticed no diffrence. I remember Danno Saying that the igniton system in our car was good enough.
Old 06-21-2005, 08:45 PM
fast951
fast951's Avatar
Of course. I just need to make the time to update the website.. We have been testing it for some time now.
Old 06-21-2005, 08:56 PM
Eyal 951
Eyal 951's Avatar
i have the blaster 2. I had a huge difference, but it may have something to due with the stock one being shot... stock = violent stumbling on boost. Blaster = ahh, much better... I figured since its replacing might as well... that and it was cheaper... only grip is its to small to fit in the stock place without having to do something to get it in.
~Eyal
Old 06-21-2005, 09:13 PM
Porsche-O-Phile
In order to take fullest advantage of a higher kV rating you'd have to (1) have longer gap for a longer spark jump and (2) fatter wires for lower resistance.
Old 06-21-2005, 09:28 PM
Missin2
Missin2's Avatar
Hmm.. well the way i see it my stocker coil probably has 170K or so on it.. I think thats "well used" at this point..
so I went ahead an ordered a blaster-2 from summit and 2 sets of fresh plugs ngk BPR7ES
it was only like $60 shipped..
cant beat that..
I am pretty sure i have a bad plug in my motor somewhere.. and i am running 14-15 lbs of boost so the slightly cooler plugs is a good idea as well..
Old 06-21-2005, 10:40 PM
Campeck
Campeck Rulez
Campeck's Avatar
I heard that the NAs get a BIG kick out of the blaster 2 coil and MSD 6 ignition.
but..what do you turbo guys care about NA's
Quick Reply: What is an aftermarket coil good for?
