Removing nose panel
Old 06-05-2005 | 08:41 PM
silverbullet's Avatar
silverbullet
Question Removing nose panel
Hey,
I want to remove my intercooler to clean all the crap thats stuck in it. I can't figure out how to remove the nose panel. I removed the 4 screws at the top. What else do I have to do?
Thanks,
Josh
Old 06-05-2005 | 08:42 PM
pikey7's Avatar
pikey7
pull the little rubber seals under the headlights, It reveals more bolts. Just loosen them though. There's a good write up on Lindseys site on the intercooler section.
Old 06-05-2005 | 08:43 PM
Cyrus951's Avatar
Cyrus951
There are 10mm bolts securing the 'arms' of the panel into the fenders.
You need to pop up the headlights to see them.
Old 06-05-2005 | 09:31 PM
silverbullet
Awesome, thanks!
Old 06-05-2005 | 09:42 PM
Rob's Avatar
Rob
There are also two screw that go in towards the intercooler IIRC.
Old 06-06-2005 | 12:13 AM
MichelleJD's Avatar
MichelleJD
Jane Bond 007
How's this? Pics are provided if you go to Clark's.
Introduction
On 924s and 944s between the headlights that holds the Porsche crest is sometimes referred to as the nose panel and sometimes as the header panel. Regardless of what you call it, there are time that it may be necessary to remove it. The panel must be removed to replace the Porsche crest. On 944 Turbos, the panel must be removed to access the intercooler. And, on the 944 S2, the panel must be removed to replace the air filter. This procedure covers the removal and installation of the nose or header panel on 924s and 944s. On early model 944s, the nose panel is spot welded in place. To remove the nose panel on these cars, the spot welds must be drilled out. To reinstall the nose panel, it can be reattached using fasteners similar to the late model cars.
Tools
Phillips Head Screwdriver
1/4" Drive 10mm socket
1/4" Drive 8mm socket
1/4" Drive Short Extension (2 inches)
1/4" Drive Ratchet
1/4" Drive Universal Adapter
Removal
Turn the ignition switch ON.
Turn the headlight switch to the ON position to raise the headlights (you'll be leaving them in the raised position).
Remove the fuse for the head lamp motor:
Early 944s (pre-1985.5) - Fuse 1 Additional Fuse Panel
Late 944s - Fuse 2 on Central Electric Panel
Turn the ignition switch OFF.
If so desired, you can raise the headlamps by removing the fuse listed above and raising the headlights manually using the knurled **** on top of the headlamp motor.
On the early 944s and early 924s, remove the header panel by drilling through all off the spot welds that hold the header panel to the body.
On late model 944s, remove the header panel as follows:
Remove the four Phillips head screws along the back edge of the panel.
Loosen the retaining nuts (8mm) in the bottom of the headlight bucket (2 in each headlight bucket). The nuts do not have to be removed completely. They need only be loosened.
There is a machine screw located under the front lip of the nose panel in each headlight bucket area.
Remove the machine screw under the lip of the nose panel using a 10mm socket, universal, 2 inch extension, and ratchet. A 1/4" Drive 10mm socket is small enough to fit under the lip of the nose panel.
Lift up on the back edge of the panel and side it toward the front of the car to remove.
Installation
If the header panel was removed on an early 944 or early 924, reattach the panel by using fasteners similar to the late 944s (see removal pictures).
Slide the nose panel into place into the headlight buckets. Ensure the washers on the nose panel studs are on top of the bottom panel of the headlight bucket.
Install the machine screw under the front lip of the nose panel.
Install the four Phillips head screws along the back edge of the panel.
Tighten the 8mm retaining nuts in the bottom of each headlight bucket.
Old 06-06-2005 | 01:23 AM
Porsche-O-Phile's Avatar
Porsche-O-Phile
It's not that hard once you pull the batwing off and look up - nose removal should only take about 45 minutes.
Old 06-06-2005 | 02:55 AM
Crazy Eddie's Avatar
Crazy Eddie
I believe there was a great amount of info on the Lindsey racing site
Its for those who purchased their bigger intercooler
As I recall it was very clearly layed out
good luck
Ed
Old 06-06-2005 | 04:09 AM
NZ951's Avatar
NZ951
That write up on clarks is good... it should take you about 10mins to take the IC off.
Old 06-06-2005 | 04:40 AM
DanD's Avatar
DanD
Remove most of the screws. Then pass a string of cars at a high rate of speed. Add a severe gust of wind. Wala. No more nose panel. (don't forget to go back and pick it up).
Quick Reply: Removing nose panel
