Vacuum Manifold (and other stuff)
Originally Posted by Laust Pedersen
The test fitting connects to the banjo bolt with the banjo KLR fitting and VM in place and all the functions (FPR, Dampener, BOW, purge valve and whatever else you may have hooked up to the 5th port) and connections can be tested simultaneously for leaks with a hand vacuum pump. There is a picture of that in the other thread.
Sam
testa, Wow, amazing graphics. You must be a graphics designer or something related. I already snatched the pictures and put them on my hard disk.
Laust
Laust
Laust
Laust
Jane Bond 007
Originally Posted by testarossa_td
Glad you like it. I do a little graphics here and there ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Hey Man
Laust,
A big thanks for a great product. I finally installed the manifold and can only say thank you. It simplified the whole system. I just looped a short piece of hose to seal up the two unused ports (for now) until I'm finished with everything.
What size vacuum hose do you recommend with these? 3mm, 4mm or what? Or do I need various sizes? I've looked at the kits but they don't say waht size hose, and with this manifold, I shouldn't need the T's, just the hsoe right?
