Oil temp sender selection
Basic Sponsor
For those interested, we have a new oil drain plug in production. It's pre-tapped 1/8"NPT which you can get both full and half sweep sending units in that thread. It's a very custom plug that has a new and much larger magnet at the end, with openings for oil to get to the sending unit. When you drill and tap the stock one, you loose the magnet thus the reason for this product. Plus unless you remove your oil pan, there is no simple way to install a sender. West's idea works, but you loose the level sender. Just another option for you to choose.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Basic Sponsor
The turbo drain? We're interested in the average temp of the oil
in the oil pan and not the temp of the oil coming out of the turbo.
Basic Sponsor
That temp difference would likely vary depending on how long you stay on boost, how much boost you run and whether it's a dry or wet turbo.
Dave... you just proved our point. Thanks. Why build something 5-10% or maybe more off when you
can do it right.
can do it right.
