Another 2.8L on eBay - Lots of RWHP!
You guys have to check this one out. I'll tell you what, if he is making that kind of RWHP @15PSI and on pump gas too, well, then I need to go back to the drawing board! Damn. I know it's just peak numbers he says, and that we don't know how the curves look, but still. Check it out. He is kind of confusing too. He expresses the power in HP in the beginning, but at the end he states it in RWHP. Kind of inconsistent in that respect. But if it is RWHP, oh boy, that's alot of power at that low of boost.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
shaheed: Sorry I beat you to it pal. But damn, "if" it's true, I'm in a world of trouble with my 3.0L 8V!
I just sent the seller a question asking him if it's in HP or RWHP and if he has dyno charts too to back it all up. I'll keep you posted.
he has a dyno chart towards the end of the ad that shows 401rwhp, so i'm guessing he means 465 flywheel. i'm still not buying the whole story without some more evidence though..
Monkeys Removed by Request
Originally Posted by turbo951fan
The intercooler pipes are stock and the intake doesn't look like it's a MAF at all. MAF don't work with stock intercooler pipes.
Anyways its clear its 465 at the crank. He's pretty straight forward about it and the dyno chart posted is 401 rwhp. Where's the confusion coming from exacty?
its 400rwhp and 465 at the crank
When you were talking 465rwhp at 15psi I was doubting him, but I'd think 401hp is possible. His mods are very similar to what I'm doing (except the stupidly over lightened crank '16lbs'!! I though 10lbs was the agreed practical maximum for our cars??). Also surely the only peice of piping you need to change is the section from the MAF to the turbo? I intend to use standard intercooler pipes with a 60-1 turbo on my car, and 55lb/hr injectors.
Ben
Ben
Originally Posted by porshhhh951
oh btw I still think 400rwhp is bs. lol.
A 60-1 with 55's aint gonna do it. At least not at that boost pressure and pump fuel.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Ben
UAE Rennlist Ambassador
The 60-1 HiFi can flow 1200+CFM, and 66lbs/hr+ easily supports 650+hp (flywheel), you just need an engine that could make such power (which is another story). The 60-1HiFi is a monster flowing, low boost turbocharger (doesn't like 21+psi boost, works very well with 10-20psi or so).
Maybe I am wrong but, didnt he just say 60-1 hifi. A 60-1 hifi which some of my friends run wouldnt get you there. And the fuel argument has been done. I dont know what fuel pressure he is running but, I bet it aint that safe. If your going for big hp why not by properly sized injectors. I guess I am wrong but, I thought the hifi was the small turbo. The 60-1 is the big brother. I promise you the 60-1 hifi's on my friends cars couldnt run 1200 cfm. So hos maybe your #'s are off or maybe we are talking different turbos. Chris runs a hifi with a t3. Now ofcourse you can swap out the turbine but, 1200 cfm.... eh.
Also I have never been a fan of authority or believed in their tunning. This guy seems to though. I dont wish to debate over some car on the net. If he is pushing that hp it aint safe with 55's. Not in my mind.
The turbo may be a 60-1. That would explain the cfm flow difference. Divine I believe very well in flow #'s posted by dave. Their 75 was way up there on cfm...in the 800's somewhere.
Tuning matters alot ofcourse still 400rwhp on 15psi and pump fuel isint a small feat or easily acomplished. I will have to go back and take a look at the dyno chart...I wonder if it was a dynojet or not.
Anyways I would like to know. I thought the hifi was the small brother of the two. Some clarification on this would be good.
