Another 2.8L on eBay - Lots of RWHP!
UAE Rennlist Ambassador
The 60-1 HiFi has a 2.75" inlet, it SHOULD use the T04B housing (turbo vendors sometimes use a T04E). The 60-1 has a 4" inlet, but the HiFi flows 90-95% of the 60-1.
Yes it can flow 1200+CFM (60-1 HiFi), due to so many various configuration of the 60-1 HiFi (various vendors assemble them) the HiFi can flow as low as 786CFM all the way to 1200CFM. This is a fact since i asked around and have a 60-1 HiFi on the way. Now, because the #8 housing is the different variable a 60-1 Hifi with a #8 stage 3 wheel about 1200cfm, or some people say 50 to 60 lbs per minute.
Just a note, the Lindsey Racing Super 75 can flow 1088 CFM using a T04E and rumors say that they use Garrett GT compressor trims (not my claiming, it is just a rumor).
Now, naturally running those hp numbers and that high fuel pressure may not be safe, but i just wanted to point out that it is do-able. Not safe, but do able.
Daniel also did 351whp at 16.5psi, running very rich, stock block and head as well.
The 60-1 HiFi has a LOT of potential that is often mis-understood.
Lads I can see this going v downward v ! Lets not start AGAIN! I was merely stating that I also intend to use a 60-1 and 55lb injectors on a 2.8 of very similar spec so if he's lying I'll know soon enough and if he's not I'll be hop skipping and jumping all the way down to a trackday to munch some jap anus! (isn't going to happen really is it!)
Ben
Ben
p.s. my info about my turbo came from here...(if it helps)
http://www.lindseyracing.com/Merchan...944TURBOSSUPER
I don't understand how he is controlling the A/F ratio if he is only using an Autothority MAF and chip? My understanding that these are basically set-up for a stock car so how would this work with out some sort of piggyback sysytem on a car that is obviously flowing much more air?
Ok, I have the answers. The guy is somewhat of a bonehead. He was consistent in the way yhe advertised his numbers. He emailed me back and said this:
"Hi I knew someone would ask this..... there is a dyno chart at the very bottom of the page. This was with the old KKK turbo(k27/6), with the new turbo, the car has not had any dyno runs, but I suspect it's making more power than b4. Probably 20-25hp. The dyno reads 401hp(old turbo)....there is approx 15% drivtrain loss, which will net about 465 at the crank."
Whew, thank God I am safe with my car, for a while!
Special:
I think you best chill my friend, your head is swelling while you're running 24PSI! And your gonna give me a beating? Well, as Duke said, do you drive your car at all? Do you have skills? Take a look at my signature my dear "dyno master friend". Its says IMSA GTP Pro Driver? And what are your racing credentials?
Also, I cant run over 18PSI, FOR NOW as you know. In due time yes. And then, when I do run your 24/25 PSI, you think you will keep up with me, on the street or track?
Dyno Charts?
Special:
By the way, "kindly" post your dyno chart of that " 438/437 HP/TQ" and at 24PSI, right? I am sure everyone is curious to see those curves. I dont ever remember you posting it?
We all will be waiting, especially me since you are going to "spot me 20HP?"
Yeah - that's what I though, man. Once again, all flappin' and no action. Check it out, my man - I went through the trouble of finding your new avatar - its friggin PERFECT for you!!!
That dyno is not, I repeat IS NOT a dyno from a K27/6 on any motor, especially a 2.8L. That guy is so full of it, I be suprised if it has any of that nice hardware in it. Funny you can't verify any of that stuff without taking things apart, huh?
Andy
Andy
