Originally Posted by Alpine951
9 times out of 10 whenever I pick up the phone I get Dan on the phone. Talked to him last night before leaving work. Email is iffy. try the phone.
Originally Posted by UK952
I would guess he looked at your sig were it says Delphi #75 injectors
Lifetime Member
Lifetime Member
Danno,
"2. turbo @ 18psi, stock injectors, GURU chips set to stock-injector size. This should run similar to TurboS, don't run max-boost beyond 4500rpm as the injectors will be maxed out around then.
I have 18 psi chips you sent me last year and I am running 18 psi with stock injectors. Does the above warning apply to me? If so, Wahhhh! I have to turn my boost down! By the way, it runs great and when I did the valve job last summer the cylinders, head gasket, etc. looked fine (FWIW).
Defending the Border
Rest In Peace
Rest In Peace
FWIW, I had the pleasure of meeting Danno at a wrenching a couple of months ago and found him very intelligent, friendly, and quick with a wrench. It's good to see loose ends getting wraped up.
