Measuring the cylinders
I've got the head off and wanted to see if the cylinders are within spec.
Where can I find a internal micrometer to measure the bores?
Has anyone replaced the rings with the engine installed? Any problems?
How did you change the rings with the engine still in the car? Did you take out the tranny so pull the crank? I'm about to have my car apart changing the oil pan gasket, don't mean to overtake this thread...
Originally Posted by badass951
All you have to do is remove the head, drop the oil pan and remove the rod bolts (check out http://www.clarks-garage.com/ for instructions on removing and installing these parts). At this point just push the piston up in the cylinder until the rings are exposed and take the old ones out and install the new ones. Tap the pistons back down and reinstall and retorque the head, rod bolts and oil pan. Make sure you keep each bearing with the rod that it was uninstalled with.
Badass
Where do I find a T-gauge and outside mic ?
I checked Craftsman but they don't carry them.
I checked prices at snapon.com. Wow even at 50% off they are expensive.
David, I just might have to figure on a drive down to borrow yours if the offer is still good?
Besides I'd like to see you car.
David
Sounds good, let me know which day and a time and I'll plan on it.
I've not been on 24 south in awhile so I'll let you pick a place to meet.
Thanks again
Thanks again
If you want to take Hwy 96 ( or 840 )over to Murfreesboro we could meet there, will have to get back with you on time and exact location.
I will PM you my cell number.
