cylinder scores
cylinder scores
Yes they look scary, but are they really that big of a deal? I have pulled apart several motors that had good compression only to find the walls pretty badly scored, like easily felt with a fingernail.
Also, what is your opinion about what causes them? Normal wear, heat, or foreign objects getting into the rings and scratching?
Finally, does anyone have a comparison of the effect of compression ratio on power with equal displacement? I think that would be interesting to look at before spending the money to get a motor sleeved, new pistons, etc.
IMHO, if you're in that deep, clean up the scratches, bring things back to new. If that involves over-boring, then so be it. It's worth it in the end (or so I hope!)
Most deep scratches are caused by foreign objects, however taper and broad scratches are usually caused by piston skirt-wall contact, which I guess could be considered normal wear.
the PO did the job. it looks like he is running 944na pistons. u can't run as high as boost like 951 pistons but i make more power down low. i plan on hitting 400rwhp at 20psi with no headwork or cam.
the engine has been this way for over two years and i have no idea after that since ihave only owned it for two years. i have ran 16psi with no problems which so ever. when i dynoed my a/fratio weren't good so i have more power to be made at those levels. Danno is runnin the same setup with different pistons. i woul dhave to ask him to see exactly what ratio they are.
Mark,
that's a very good question; I wondered about this as well
I myself have witnessed scratches like you describe and that particular engine showed no signs of decreased compression or even burning of oil.
I was told that with age it's a little carbon buildup on the rings/lands doing the scratching. So, I don't know.
Apparently, if the compression goes up from, let's say, 8:1 to 9:1, the thermal efficiency goes up from 28% to about 30% (give or take; but the gap is around 2% give or take a bit). This realization of two percent gain in thermal efficiency turns directly into power!
Therefore 30/28 or about 7% increase in power.
As the CR goes up the increase in thermal efficiency gets to be a little less, however.
Thanks Tommy, thats just what I was looking for.
I have a block that is pretty badly scored, I think for the hell of it this summer I am going to build a 951 motor with NA pistons and lots of used parts, then just see how much power I can make before blowing it up. I have nothing to lose as sleeving is way too expensive and used na pistons should be almost free.
