removing vac line to KLR....
Other than the obvious of no overboost protection or factory boost gauge, what can I expect to happen if I disconnect the vacuum line going into the KLR?
Lazer Beam Shooter
Car will go into Limp mode as it will see no boost pressure when it expect to see boost,and thus limiting boost to 0.2 bar.
Just had a plugged line to the KLR, and thats what it did.
Regards B.O
Regards B.O
I'll second that the car will go into limp mode - been there, done that. It's just a safety check to make sure the boost system is working properly. AFAIK the KLR *doesn't* use the boost pressure to control boost - that is it's not in closed/feedback loop.
--Brian Morris
89 951
--Brian Morris
89 951
Originally Posted by xsboost90
could you use a boost controller to bleed off pressure to the klr to regulate the overboost protection down or would that just blow your engine up?
The DME is measuring air flow through the AFM, and if that air flow exceeds a preset limit, the DME determines that the car is running too much boost (or that there is an intake leak), and it triggers the overboost protection and cuts the fuel. Its not a function of the manifold pressure line running to the KLR.
If you swap the factory DME chip with an aftermarket chip, and leave the KLR chip stock (e.g. Vitesse chips), you can run as much boost as you want w/o tripping the overboost protection.
