argghhh wastegate line issues.
Monkeys Removed by Request
Okay it seems after it happened for a second time tonight that this isssue isint going to just go away and I need some rennlist suggestion's. Some background
A few weeks ago while I was boosting a little maybe 17psi or so my boost suddenly dropped and dropped hard. After that I could only build about 8psi of boost pressure at all in any gear at any rpm! I was pissed to say the least cause at first thought I was concerned my clutch had finally given way. My clutch is been getting weaker and weaker and it didnt have long. I did some testing and I didn't feel any slipping at all. So it obviously wasen't the clutch. My vac readings were 19HG at idle and 21 in gear. Hmmm no vac leak. I double and tripple checked every line I could find and they were all connected properly. So I pulled my controll panel off and looked behind my boost controller. I have two vac lines running on this lindsey boost controlller. They were connected fine. Hmm
I jacked the car up and looked at the wastegate thinking oh **** there go's 400 bucks. Looking at both ports the top one had the proper vac line but, the side one didn't. I looked around with a flashlight and found the line. I plugged it back up and took her off down the street. Ahhhhh booooooost!
So I was curious why after all this time my line would blow off like that but, I just didn't think much of it. Until tonight. I was playing around with a friend of mine david and his new 400HP GTO. Until suddenly bam! No more boost again relying on the spring pressure of the wastegate. ****
So my quesiton is. Is this common? What can I do to make sure the line doesnt blow off again? What might be causing this? Are my lines getting old or something and need replacing?
Any help would be greatly appreciated as I dont want to have this happen at the track or something that would totally suck. Going from 20psi to 8 hurts
BTW those new 400hp GTO's arent all that fast
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Bret you think a tie wrap will hold just fine?
If so thats a pretty easy fix. Should I be worried about anything else?
At 20 I'm not sure but a tie wrap should do it. I've also used some small metal spring clips that you can get at HD and Lowes but they stretch out after several times on and off. I think your line just lost the "bite" after all the work you've done.
Thanks for the help bret I am in your debt.
BTW can you point me in the direction of a good cage? I still havent ordered one yet and I really need to get one in the car. Thanks again.
Depending on what we(jim and me) do with the cage that we got out of the race car, we may have the main section to sell or give away. I'll keep you informed.
Sweet!
RobNL,
Where do you get those hose clamps ????
They look just like the original factory version.......I've been trying to find those without success. The Swiss Porsche dealers are of no help....
Tommy
Tommy
Originally Posted by tommye
RobNL,
Tommy
Tommy
![](http://www.carina-technik.de/images/090.jpg)
When you do a search at Google look for "Ohr Klemme" you'll find enough shops in Germany or other German speaking countries that have them.
For example here: www.spenglerwerkzeuge.ch
You can also find those particular clamps and many other varieties at http://www.mcmastercarr.com
Do a search for Nylon Snap-Grip Hose and Tube Clamps. They look great for holding vacuum tubing, and they are good for more than one-time use.
No I don't work for them, they just have tons of useful items!
*hint-hint* even silicon tubing
