to retard or not to boost?
Darius, As I recall you should be running about 3.5bar FP.. Also use the PB for fine tuning...
Drive-by provocation guy
John how much does fuel pressure affect the mapping?? Before new chips are needed.
Also, is there a "ballpark" for timing v.s boost?? I.e. for every 2-3 degrees retard, you can 1 more pound of boost?? (assuming egt's are ok)
