RPM signal 0-5v
Hi All,
I am looking for 0-5v RPM for logging looking at the DME pins out there are pin 8, 27 and 21. I hook up to pin 21 going to the tacho but found that this is pulsing 0-10v.
Can anyone shed some light on which pin I should use?
Hey SpecialTool, what's this in your avatar?
Before hoocking up the Tach signal, make sure tio read the instructions for your Data Logger, some of them autocalibrate, some do not...
Brett,
You should be able to hook up DME Pin 21 to either one of the speed inputs on the M-500. The manual states that the M-500 will clip the speed inputs to 5V and DME Pin 21 will not exceed the 25V maximum of the M-500.
