View Poll Results: Which Gauge should I buy?
Narrow band A/F ratio
13
52.00%
Oil Temp
3
12.00%
Water Temp
1
4.00%
Volts
0
0%
Oil Presure
1
4.00%
Some thing else (post your gauge)
7
28.00%
Voters: 25. You may not vote on this poll
POLL:!! Which gauge should i buy?
Old 02-11-2005, 04:22 PM
Ian Carr
That Guy
Ian Carr's Avatar
Default POLL:!! Which gauge should i buy?
OK this is basically the same as my other post but im going make this one a poll... I need to know what gauge to get with a boost gauge. I heard a whole bunch of different gauges. I live in connecticut so oil temp is not a huge issue. MAKE YOUR VOTE HEARD!#@!@#$@$^%@% OR DIE!
VOTE
thanks all,
-IAN
p.s. these will be going in the gauge pod that Hosrom has hooked us up with a discount so go buy one! https://rennlist.com/forums/showthre...6&page=5&pp=15
And it will be my boost gauge on top and the poll is for what gauge to get on the bottom.
Old 02-11-2005, 04:24 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
How about fuel pressure????
If you're dash clock is not working, get the narrowband from rennbay (drop in replacement)
If you're clock is working........fuel pressure gauge or narrowband (since you are not concerned about oil temperatures)
Thanks for that link
Old 02-11-2005, 04:28 PM
Ian Carr
That Guy
Ian Carr's Avatar
can you run a fuel presure gauge inside?? i thought you can only run one ON the fuel rail... interesting..
Old 02-11-2005, 04:30 PM
Cyrus951
Cyrus951's Avatar
You can drill and tap for a sender and route it to a gauge inside the cabin.
Old 02-11-2005, 04:33 PM
Ian Carr
That Guy
Ian Carr's Avatar
Ahhh... Hosrom quick question is the gauge pod ment for 2 1/16 or 2 5/8 ?? im guessing 2 1/16
Old 02-11-2005, 04:38 PM
hosrom_951
hosrom_951's Avatar
2 1/16"
You could use an electrical gauge.........
Old 02-11-2005, 04:39 PM
Ian Carr
That Guy
Ian Carr's Avatar
Thanks im going to place my order right now
Old 02-11-2005, 04:44 PM
fortysixandtwo
fortysixandtwo's Avatar
I voted for the narrow band. Only because most of the selection would be redundant to the factory guages. Also it would depend the tune of your engine, which I'm assuming is close to stock. (chips, exhaust, MAF/MAP, boost enhancer, shimmed waste gate is close to stock)
Old 02-11-2005, 04:48 PM
azmi951
azmi951's Avatar
VDO EGT
Old 02-11-2005, 04:57 PM
Ian Carr
That Guy
Ian Carr's Avatar
Originally Posted by azmi951
VDO EGT
I was told by one of my buddys to never buy a exhaust temp gauge... he said it was so pointless to have for every day driving..
-IAN
Old 02-11-2005, 04:58 PM
NZ951
NZ951's Avatar
WB O2.
EGT It is pointless if you have not "tuned" your car and drive like a Nanna.
Old 02-11-2005, 04:59 PM
SamGrant951
SamGrant951's Avatar
I have to disagree with your friend, an EGT gauge is far from pointless. Narrowband on the other hand, thats pretty pointless.
hosrom_951
hosrom_951's Avatar
I would go for EGT only if you are REALLY going into tuning the car you're self (talking timing here)
Old 02-11-2005, 05:03 PM
hosrom_951
hosrom_951's Avatar
Originally Posted by Scootin159
The mechanical ones CANNOT be mounted inside as they require a fuel line run to them.
Imagine if you get a fuel leak !!!
Old 02-11-2005, 05:06 PM
Ian Carr
That Guy
Ian Carr's Avatar
Yeah i was gona say... running fuel lines into the cabin?!? Thats interesting i might be interested in that.
"Narrowband on the other hand, thats pretty pointless." How so wouldn't you want to know if your running rich or lean?!?
-IAN
Quick Reply: POLL:!! Which gauge should i buy?
