Logging boost on DL1 data logger
Well, there you go. If it is a generic input, it will give you a value of 0-5 for voltage - which you need to convert to %, or psi.
There are graphs on the web which give conversion tables for the GM sensors.
You will get something like 3.75 volts on the screen, and you can convert to something like 18 psi. It becomes second hand after a few readings of your software.
For those interested and PM me.
You can get it at DigiKey part number MPX4250AP-ND
Detailed spec:
http://rocky.digikey.com/WebLib/Moto...A%20SERIES.pdf
Detailed spec:
