build my own boost controller...
Old 04-12-2005, 01:22 PM
  #91
toddk911
Drive-by provocation guy
toddk911's Avatar
I think my regulator I ordered is bad, as some runs it I can make the boost that I set, then other runs it only makes about 8-10 psi. Put the reliaboost back on and it is fine. Put reliaboost on with relief and fine. So it looks like the regulator might be bad.
Old 04-12-2005, 01:56 PM
  #92
mroberts
mroberts's Avatar
I have one concern with the check valve setup. It looks like the Audi boys are running it back to just upstream of the relief valve. Do they get their pressure from the IC (like we do in stock config) or from their manifold ?
If it's the IC, then at no point does that ever go to vacuum.
If it's the manifold, and you shift quickly enough, you don't necessarily generate a whole lot of vacuum in the manifold, right ? You will also end up dragging the WG line down to a varying pressure rather than 1 bar if you had the check valve to the atmoshpere.
The relief valve will open with a pressure differential, rather than an absolute pressure on the upstream side, so when it opens will be determined by the varying pressure in the WG line. I'd be worried you could "pump up" your boost by repeatedly backing off a little. This would let the releif close, once the pressure on both sides equalised.
i.e. for releif at 15psi: Boost to 15, back off to 10. P(WG)=10, P(IC)=10
Boost again. P(IC) has to go up to 25 psi before you get a differential of 15 across the releif valve.
Of course, I'm just an engineer so this is all theory. Reality may be a completely different beast
Old 04-14-2005, 11:26 AM
  #93
J Chen
J Chen's Avatar
Hi Toddk,
The Reliaboost takes the place of the relief valve.
You must keep the regulator. For sure you will not
see any diff since you're running with 2 relief valves.
You're forgetting that the Reliaboost is a relief valve
Old 04-14-2005, 11:33 AM
  #94
toddk911
toddk911's Avatar
Yea, I realized that after I posted
Old 05-09-2006, 05:13 AM
  #95
DLS
DLS's Avatar
Old thread
How many are running this "boost machine" here?
Have you guys built it exactly like the drawings on this page?
http://public.fotki.com/ttschwing/bo...matic/bm1.html
Old 05-10-2006, 06:27 AM
  #96
DLS
DLS's Avatar
no one running it??
Old 05-10-2006, 08:54 AM
  #97
jimbo1111
jimbo1111's Avatar
These are sold commercially.
http://www.boostcontroller.com/index...6category%3D26
They work well if you have a single port wastegate but are not the recommended conrtoller for a dual port setup. Dual port requires the use of a bleed type controller.
Old 05-10-2006, 09:55 AM
  #98
Oddjob
Oddjob's Avatar
Originally Posted by DLS
no one running it??
I dont know if any 951 guys are using that setup exactly as shown, since that is for the Audi 1.8/2.0 Turbo motor using the Audi ECU controls and N75 Valve (which sounds somewhat similar to the 951 Cycling valve).
Someone that is familiar with the Audi system could comment on the differences/similarities between it and the 951 setup.
Offhand, I do not see what the benefit would be of running the WG control line through a pressure relief, through a pressure regulator and through the cycling valve, before going to the WG diaphram on the stock single port WG on a 951. Seems like more of a mess than anything actually beneficial.
Old 05-10-2006, 11:22 AM
  #99
DLS
DLS's Avatar
But doesn´t toddk911 and Douglas Sorrells use the boost machine?
Old 05-10-2006, 11:44 AM
  #100
sweanders
sweanders's Avatar
It seems like an overly complicated solution since running an MBC only works very well. If you are running stock turbo and wastegate I recommend the accuboost but some people prefer the bleed type valves.
Old 05-10-2006, 12:37 PM
  #101
toddk911
toddk911's Avatar
Yes, I built one and used it but did not see any noticable results.
I tried several configurations and still no noticable results.
Old 05-10-2006, 12:55 PM
  #102
DLS
DLS's Avatar
hm now i´m confused???
what shall i do??
Old 05-10-2006, 01:32 PM
  #103
Douglas Sorrells
Douglas Sorrells's Avatar
I have been using the boost machine and very happy with it. Spool time is crazy short (1 bar @ 2700 rpm & 2 bars at 3600 rpm). 20 lbs of boost is quickly on hand in all gears including 1st (Limited at 20) I currently do not have the 1 way valve in place, but I'm going to try it again shortly. It was seeming to defeat the pressure regulator when I initially installed it, but I had leaks all over the place. I've got the system pretty well sealed up now. D
Old 05-10-2006, 02:44 PM
  #104
DLS
DLS's Avatar
do you run the tial in dp?
Old 05-10-2006, 04:45 PM
  #105
Douglas Sorrells
No I currently have it setup as single port. Wasn't sure how to set it up as dual port.
d
Quick Reply: build my own boost controller...
