Turbonetics Experience
#33
Originally Posted by hosrom_951
Serial: are you using the same set-up as i mentioned? (#8 hotside, oil lubricated and water cooled etc)
PS: is that a 60-1 or a 60-1 HIFI (your intake looks more than 2.75")
the turbo is a GT76 BB Q2 trim.
#34
Skunk: I was also told that the BB are a nightmare if not impossible to rebuild if the bearings fail???
#35
I got my turbo from them, TO4E non ball bearing and was fairly happy. I ordered the turbo with standard housing and it came polished (bonus!!!). Other than that, the turbo has done really well with about 5k on it now.
#36
Originally Posted by serial_modder
nah, me and Skunk are going all the way with full customization of the entire engine.
#37
UAE Rennlist Ambassador
hmmmmmm......maybe i should stick to a standard bearing turbo then........
But again, i would like some more input from Turbonetic's turbos on the 951's (using the KKK hotside).
#38
tony ran a full garrett as far as spool realize he was running a #3 milledge cam and had extensive head work. As far as BB turbos singles tend to leak while duals are lesss prone too. As far as spool-up between BB and nonBB turbos BB sweep faster, ie ident turbos exc for the bearings say 0-5 psi would be about the same above that BB build boost quicker also BB turbos tend to stay spooled between shifts quicker than nonBB turbos.
#39
#40
Thanks for the explaination. Wouldn't the rotating shaft tend to stabilize itself naturally though (especially at higher speeds) due to gyroscopic action? I'm assuming the assembly is balanced properly.
#41
#42
Good post Hosrum. Thanks for asking the question. Hopefully you'll get an answer from someone that addresses your specific question. Either way, the info here has been awfully helpful to others. Thanks E
#43
Guys, did any of you actually test the spoolup between 2 identical turbos with standard and 2-BB turbos?
I think you will be surprised!!
#44
Originally Posted by daniel951
I know one person down here in colorado went to turbonetics in golden Cpt_Koolbeenz and got a bad turbo made by them and screwed up his rod bearings and bottom end of the engine. He is now fighting with them in a lawsuit. Other then that it seems like alot of people in the import world go with this company
-Joel.
#45
