AHHHH Brake Fade
1 Post
Do Not use pbr axxis pads!!!
I just got back from a drive and those are horrid pads with tons of fade!
So I need new pads, anyone got a full set of something better? preferably front and rear?
recomendations?
thanks!
By the way the Tial 38mm is really fun!!!!
recomendations?
thanks!
what he said...then drive 600 more miles. Aftter that, you may begin to have a case. Brake pads wear into a "zone', where they are at their best. If it doesn't happen, switch to something else. Good luck. I wouldn't change mine until they get too worn. At that point, I'll be irratitated until the new ones get in the zone. Then I'll feel as confident as I do now. Good Luck. Happy holidays! E
Originally Posted by pk951
You would be better off with Hawk-HP-PLUS run those on my VW great pad for street, and maybe some DE's.
On my 951 Pagid orange no fad with these.
Originally Posted by Porsche-O-Phile
OE would almost certainly be the best. I have OE on the 951 and just put Mintex on the 944. They seem fine thus far. I will probably switch back to OE once these ones die though.
No kidding? I thought the OE pads were designed especially for that. First I've heard of significant fade with them. . . Maybe it's a combination of factors like bad / old fluid, pads, etc?
i still gotta say that porterfield pads beat all other pads regardless of price.
-no fade
-no dust
-silent
-easy on rotors
-stops on a dime, even when cold
-cheap! (only $80 per axle)
http://www.porterfield-brakes.com/pads.html
the one to get is the r4-s
edit: i am not affiliated with porterfield in any way other than being a happy customer.
-no fade
-no dust
-silent
-easy on rotors
1 Post
They are a few months old but this was the first time driving on a twisty road (none in Michigan). They should be broken in after a few thousand miles, unless they need some extreme heat to get them to bed in and in that case I still would try to avoid them for hard use
however they do not make noise and are REALLY clean so If you want a stock replacement then they are ok.
I have Mintex C-techs in the front and stock in rear...the fronts are noisy but catch good when cold and slow speeds but man do I love them at high speeds!!!
