Coilovers that delete the T-bar
#31
Ooouch turbite, that is damp stiff for street.
I run 300 fronts with 400 rears. For me, I
feel that 250 fronts & 350 rears will be a
good set up for street & if you want to do DE,
put on a set of adjustable front & rear sway bar.
#34
There is alot of info on the board about spring rate and wheel rate ratios, I think the front is .9ish and the rear is .56 if I remember...So what the effective rate at the wheel is will be 90% of front spring rate chosen and 56% for rear.
#35
Former Vendor
https://rennlist.com/forums/showthre...ght=wheel+rate
According to this you can choose between .44, .56 and .65 for rear wheel rate depending on who do you believe....
