Aftermarket sway bar bushings ?
I need new sway bar bushings. I use the car for auto-x and DE's, and have 200 lb coilovers at the front.
Does anyone make an "improved" front sway bar bushing (for the stock sway bars), and are they worthwhile ? The car is in the shop as we speak having failed inspection for the bushings.
Any help ASAP would be appreciated.
Also, they said the bushings were destroyed by a leaky "oil pressure switch" - is that the same as the oil pressure sender ?
Paragon and Pelican list the pressure sender as #PP928.606.203.01 for about $60, but the shop quoted me $95. Pelican also lists an "oil level sender" at $88.
Thanks,
Mike.
Thanks,
Mike.
Check these out:
http://www.paragon-products.com/prod...mc-4100set.htm
http://www.paragon-products.com/prod...re_mc-4000.htm
These are from Racer's edge and I have heard they are nice. I am going to install the fronts, but I have a Weltmeister rear so I can't use the rear.
As far as the oil pressure switch, I am sure someone with more knowledge can chime in.
Max
Max
Thanks for the help.
