HEADLIGHT problem... HELP!
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
Hey guys, I got another problem with my 951. This is the first time it ever has happened. I drove the car today and at night I went to a restaurant. After I parked, I shut the car off and noticed a clicking sound. I couldn't find where the noise was coming from in the interior. It turns out my headlamps (headlights) were opening and closing and opening and closing, etc. and wouldn't stop. The first thing I thought to do was to start the car again and turn the headlights on and off but the same problem occurred. I disconnected the battery, ate real quick, went back out and connected the battery and it stopped. I drove home and once again, after I turned the headlights off it started popping up and down, up and down, and so on, regardless if the car is on or off.
Temporarily, I took the fuse out for the headlamp motors until I can solve this problem. Any ideas? Thanks again for your time guys, I really appreciate it!
That Guy
OMG i thought i was the only person that happened to! Some times messing with the light dial works BUT!!!!! I was told there is a like a censor on the headlamp motor that you should unplug and clean the conectors... let me know what happends
Hey guys, thanks again for the replies. I have tried fiddling with the switch to make it stop and sometimes it will stop. But how will I know it won't start popping up and down when I am away from the car?
Thanks again.
Thanks again.
