Quick! Help me decide whether to buy it or not
I'm looking at an 86 951 with 100k on the clock. I just had the PPI done and everything looks pretty good except one thing. The compression test results were:
1st time:
135, 120, 135, 135
2nd time:
130, 125, 135, 135
I talked to the mechanic and he said the test was done at WOT with all plugs removed. He told me it wasn't really anything to worry about and he has his own shop and works on Porsche/BMW exclusively (and sounded like he knew what he was talking about). It looks a little low to me -- anything to worry about?
Other than that the only problems were really a few weeping hoses and some minor sound from the torque tube/driveshaft bearing.
Everything else sounds like it's in good condition so I'll be taking a trip to check it out & possibly buy it this weekend. He's asking 9k.
1st time:
135, 120, 135, 135
2nd time:
130, 125, 135, 135
UAE Rennlist Ambassador
Was the engine warm when the compression test was done?
As for the noise from the TT, if it turns our to be the bearings is a major PITA and time consuming.......
Spell Checker
I was going to say the same but I didn't want to get slammed by the "9k isn't too much" group I have seen here before. As for whether to get a leak-down relative to the percentage... like sam said, on an older motor just get the leak-down. Better test. What is common to check when you get a PPI on one of these cars?
Yeah the asking price is a little high, but the belts, rollers, water pump, clutch, and power steering rack were all replaced within the last year or so
Monkeys Removed by Request
no way I would pay 9k for a 86....sorry. If it's what you want then get it but, the car sounds like its not perfect and a 86 asking 9k it should be.
By a 88 or 89 for around 9. If not then by a 86-87 for 7-8k in pretty good condition.
The market in CA is a little higher than in other parts of the country. But we have the "rust-free" samples to choose from. ;o)
I've noticed that CA prices average around $1K higher than in other places. I agree with Cyrus951 on the $7500 bite. Never know until you ask.
Remember the line in Python's Life of Brian: You must haggle....
That Guy
WARNING! When i did the test it was
135,135,115,125
The rings are gone and i now have two scored cylinders![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
TO CHECK!!!
Put oil inside the cylinder that has a low presure, if the presure goes up itll be your rings(the oil would seal up any leak around the rings). If it stays down it would be a valve problem![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
hope this helps
-Ian
135,135,115,125
TO CHECK!!!
hope this helps
-Ian
