Show your 951 pics here......
#2942
they only rub if I hit a bad bump or fast shift 1st to 2nd gear. I need to upgrade the rear springs to a higher pound spring. The rear lips on the quarter panels are rolled in. The rear tires would not fit if they weren't stretched to ****. I still have lots of 18x10 wheels in original boxes. I have 5 or one offset and 3 of the other. I just dont have a backup for the rears (18x11.5).
#2945
Which of your cars do you have your current wheels on? I'm running 52's on all 4 corners. What offset are you running in the rear. These wheels look even better with the dish that your rears have. I found that I couldn't run 285 on the rear. IEven with rolled fenders it still won't fit. I have an odd rubbing on the front right, also 52, but not on the front left. I'm trying to figure it out.
#2946
That fitment looks really good, and I am wondering what size/offset/tire as well... release the specs LOL. I hate the fact that I don't have a clue what offset mine are. Still learning.
#2948
What year is your car, and are you using spacers. We can probably tell you what you have.
#2952
The rear have offset of 43. They stick out a bit far but the negative camber tilts the top inward. Also, the 285 on an 11.5" wheel helps it clear. It only rubs it you hit a hard bump or hard shift second gear
#2954
