Exhaust Leaks? Tricks to find them?
You have to be quick, but spraying the COLD exhaust with a soapy water solution works great.
You have to start with a cold car, jack it up and get everything ready.
Fire it up and have someone rev it slightly while you quickly spray the flanges and pipes
and mark or make a note of the bubbles.
On a cold car I just have someone start it while I'm underneath, and I pass my hands around all the joints to feel for hot exhaust gas. On a cold, idling car it's difficult to linger long enough to burn yourself.
Sam
Sam
Use a shop vac exhaust to force air into the end of the tail pipe. Use some wet rags to help seal the tail pipe.
Once you have that running, you can use a spray bottle of soapy water to locate air leaks.
gb
gb
Same as Sam and Jeremy here. You have maybe 30 seconds (for each cold start) to find the leak. The effect will be enhanced if you partially block the exhaust.
Drive-by provocation guy
Yep, found some. Found a bunch of little ones!!
Used the leaf blower up the tailpipe with a rag wrapped around it and let her blow
Then sprayed with soapy water. Started blowing bubbles in several places, mostly around the wastegate area and crossover.
However, the bolts are as tight as I can get them and they are very small leaks, about 4-5 I guess. Now is this enough to loose 3 psi????
I can try some high temp sealer, but other than that I am not sure how to better seal the areas.
HELP?????
HELP?????
Unless your pipes are cracked, it can only be the flange seals - each of those has a crush ring that needs to be replaced (at no small cost) - did you replace them when you disassembled them? If not, that's why they're leaking.
Sam
Sam
Crap!!! No, I pulled the wastegate to put the GURU unit on about 1.5 years ago and no problem until now. Did not put new seals on. Any other way to seal it???
Also, would a few small leaks account for a 3 psi loss???
Sam
Sam
I'd say just suck it up and get new ones though. It's probably not enough to be the cause of your boost loss but it's definitely not helping either. Who wants to breathe exhaust anyway? You *might* be able to get away using some of the copper spray gasket stuff if you pulled it apart but I'd say just get a new ring at that point if you take it apart.
Gotcha.
ok, then where else could I be loosing the 3 psi??
Fyi, got good vac and did the wastegate test; i.e. unhooked at banjo and capped it off, and still only about 15psi. It makes 15 but also holds it, no roll off. And wastegate is a GURU unit which I know is fine.
So the boost loss has to be in the exhaust line/pipes right???
