Major cleaning (edit: HIGHLY Recommened)
UAE Rennlist Ambassador
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
The IC is out and sitting in the bathtub covered in soap and ready to be cleaned
I syaped water, and so much junk came out of it....including some bird feathers![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I also cleaned some ground wires using sand paper, made them shine brown/bronze again.
I found the water temp sensor for the gauge wires to be green and corroded. Spend 15mins alone just returning them to bronze/brown again, same goes for the negative battery cable mounted on the car, and the headlight grounds on both sides (expecting grounds to be solved since everything else was cleaned).
Now, besides paint thinner and petrol, what else is strong enough to remove junk from the IC? im using a sponge and dishwashing soap. I don't want something too stronge and if anyone has any tips for 'while im in there' please let me know.
TIA!!!
TIA!!!
NZ951: Ok, the 4 screws on the panel need to be removed. Then pop up your headlights and you shall find two small 8mm nuts on each side that hold the panel, take those off (mine was a pain to remove since they were REALLY tight, WD-40 HELPS like mad).
Then, just slid off the panel. However, there are another set of 'hidden' screwed that were not one mine. There are also two plastic nuts (another pain) that hold the 'plastic flow' for the IC. Wiggling while pulling forward and lifting upwards removes the IC.
Here is a link to Lindsey Website with pics that helped out :http://www.lindseyracing.com/swap.htm Follow steps X to 12 to remove the IC
Special Tool: Hey, my finger nails are dirty, how to clean them ? i am also thinking of painting my seats and there is green stuff leaking from the front of my car, what is it? What are the materials of the IC pipes, lug nuts, wheels etc![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
The above statement was referred to the 'I cant take it anymore' post![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
But thanks anyway, i got it clean. dishwashing fluid and a sponge does good results too
Ok I think you misunderstood, are there only the 4 nuts holding the IC on? I already have the header panel off etc and deleted the plastic IC duct... I will look at Lindseys write up...
Yes, just 4 nuts holding the IC on....
sorry
im DEAD tired (try working outside when the temp is 104F
) and i STILL need to re-install things back
please excuse me
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
lol I was out taking it off while you were posting... ok, so cleaning technique... I have some engine decreaser did a search on here and I am into it, will be interesting to see what comes out after 18 years! Good thing the IC spayer will be cleaning the outside from now on
Gotta love those 931 vents and new duct!
Ok, everything is installed and went for a test drive. Waited untill the oil reached opt. temp and floored it on second gear....
WOW!!!!.......boost hits HARD, at 3,500rpm (when i floored it) the rear wheels were slipping
what a BIG difference!!! The thing is, i left the IC air duct out, as in i didn't install it back thinking i woul dget more air in??? any comments on that?
Anyway, i posted a thread here a few days back regarding a strange noise i get (BOV noise) while shifting....https://rennlist.com/forums/944-turbo-and-turbo-s-forum/158201-bov-sound-but-i-don-t-have-a-bov.html
The sound is gone, i went from 2nd gear all the way to 4th, hitting 190km/hr (~110-120mph or so) the car NEVER felt this quick, what a difference.
I HIGHLY recommend cleaning ths IC and IC pipes for EVERYONE!! such a difference, feels like a new turbocharger in there
nice and smooth and reved faster (i think
Even the temp gauge gave me better readings (not 'jumping' to third white when fans kicked in, stayed nice and cool just over 2nd white mark on boost in this heat!!!)
Registered User
I clean my IC every year ... I use aluminum (wheel) cleaner on outside and industrial soap on innside ...
Not to forget the rest of the engine bay... keeping a cleen engine makes it easier for diagnostic and maintenance..
UK952:
for some reason, after all this, i cannot re-install the IC air scoop
it's actually harder to install than to remove. Maybe next weekened i shall give it another go......
Registered User
It`s a pain. Mine is actually broke ... this ofcourse makes it alot easier.... ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
anyone tried to heat the duct using heat-pistol!! ?
Would this make it more flexible?
After the cooling air comes in through the front intake and then goes through the duct and intercooler heat exchanger, where does it go then? In other words, where does the cooling air exhaust?
