Zeitronix logging
I wired one into a buddies car... TPS is useful in the tuning process.
On a side note, anyone having EGT problems or weird cutouts at higher RPMs? Cutouts of the Zeitronix, or EGT not working.
Originally Posted by special tool
I just dialed out a very slight lean stumble from my cam at 3k revs in about 2 miles - just by watching the tracer. Laughed my *** off.
I like the Zeitronix software, with the help of Shaheed, it was a VERY simple process. I have a LM1 unit, but for fast live tuning I think the Zetronix is much simpler/quicker to use... Of course you can always log the Wideband signal in the SMT6, but not as granular as the Zeitronix siftware...
Shaheed, let me know when you want to get together to complete your boost setup...
john,
car is on jackstands right now, started replacing the control arms with a set of steel arms but the drop links for the sway bar aren't fitting properly. as soon as i get that straightened out i'll drop you an email. and i appreciate your offer to help as always
theedge: a U2 fan?
My zitronix EGT works great! Have noe problem at all at any rpm. Very useful to have!
Agree with John that zeitronix is a very easy, cheap and nice products! Easy to tun/log with all the stuff, boost, rpm, lambda, tps and EGT.
Shaheed, make sure you have the drop links facing the correct way front to back. It sounds dumb but I made this mistake once, even after having done the job several times before.
Mark
Mark
